ok still working on it..
duck
Post by duck »
ok, Ive been cuttin and pasting and getting through most of this, however Im getting an overheat shutoff, I dont have any overheat temp specified, i havent cut and pasted that yet.. I goto overheat clear and my lights skimmer come back on. cant figure that out yet.. I am using the temp1 sensor and the simple menu says error on t2 and t3.. i would assume i have to disable them? heres my code so far, I dont even know if I need all of it, lolim just piecing it all together.
#define DisplayImages
#define DisplayLEDPWM
#define DateTimeSetup
#define DirectTempSensor
#define StandardLightSetup
#define wifi
#define SIMPLE_MENU
    #include <ReefAngel_Wifi.h>
    #include <ReefAngel_EEPROM.h>
    #include <ReefAngel_ATO.h>
    #include <ReefAngel_LED.h>
    #include <ReefAngel_Relay.h>
    #include <ReefAngel_PWM.h>
    #include <ReefAngel_Timer.h>
    #include <ReefAngel_Memory.h>
    #include <ReefAngel_Colors.h>
    //Actinic and Daylight PMW are on the LED moonlights
    byte ActinicPWMValue=0;
    byte DaylightPWMValue=0;
    byte wmport=Port5;
    boolean wmdelay=false;
    byte wmpulse=0;
    #include <avr/pgmspace.h>
#define Phillips6610LCDInv Phillips6610LCDInv
#ifdef Phillips6610LCDInv
#include <Phillips6610LCDInv.h>
#endif
#ifdef Phillips6610LCDInv2
#include <Phillips6610LCDInv2.h>
#endif
// T5                  1
// FAN                 2
// FUGE                3
// ALK                 4
// PH1                 5
// HEAT                6
// ATO                 7
// SKIM                8
  ReefAngel.OverheatShutoffPorts = B10100001;
  ReefAngel.FeedingModePorts = B10010000;
  ReefAngel.WaterChangePorts = B11111001;
  ReefAngel.LightsOnPorts = B00000011;
  ReefAngel.PHMin=529;
  ReefAngel.PHMax=819;
  ReefAngel.Relay.On(Port8);
  // Specific functions
  ReefAngel.StandardLights(Port1,11,0,21,00); // T5 Lights
  ReefAngel.StandardLights(Port2,11,0,21,00); // Light Fan
  //Powerhead On Every 4 Hours With 30 Min Pause
  if (now()%1800<12600) ReefAngel.Relay.On(Port5); else ReefAngel.Relay.Off(Port5);
  //Heater Control on at 76.0F and off at 76.8F
  ReefAngel.StandardHeater(Port6,760,768);
  //Alk Dosing Pump 1 Minute Every 16 Minutes
  if (now()%960<60) ReefAngel.Relay.On(Port4); else ReefAngel.Relay.Off(Port4);
  //Reverse Photoperiod Refugium Lighting (Port 3 as compared to Port0)
  if (!bitRead(ReefAngel.Relay.RelayData,Port1)) ReefAngel.Relay.On(Port3);
     else ReefAngel.Relay.Off(Port3);
  //Moonlight Both PWM Ports; Using Actinic
  //Old ATO{Port 7)
  //  if (ReefAngel.HighATO.IsActive()) ReefAngel.SingleATOLow(ATO);
  //    else ReefAngel.Relay.Off(ATO);
       if ( ReefAngel.LowATO.IsActive() )
          ReefAngel.LowATO.StartTopping();
          ReefAngel.Relay.On(Port7);
          ReefAngel.LowATO.StopTopping();
          ReefAngel.Relay.Off(Port7);
       if ( ReefAngel.LowATO.IsTopping() && ! ReefAngel.HighATO.IsActive() )
  ReefAngel.Relay.Write();  // Make relay changes effective
lemme know what you think I need or dont need..
rossbryant1956
Re: ok still working on it..
Post by rossbryant1956 »
The one answer I can give is about the T2 & T3 temp sensors. Roberto told me unless they are plugged in they will return an error on the simple menu. As to overheating I am betting it is something that got set in your internal memory. The forum helped me last nite with a ph issue that got set by loading internal memory
Try loading a internal memory file.
duck
Post by duck »
how do I load that? is it on the download page?
aha, found it on ragen..
uploaded
bingo!
