What code do I need to delete remove T2 and T3 from showing up on the main screen?
Remove T2 and T3 on main screen?
Re: Remove T2 and T3 on main screen?
You will want to do a Custom Main screen. The main screen drawing is lumped together in one function by default. If you want to customize and change things, then it's recommended to switch over to a custom main screen.
Check out the guide: http://forum.reefangel.com/viewtopic.php?f=14&t=109
It does show you how to re-create your main screen without the T2 & T3. If after reading, you still need help, just ask away.
Still can't figure it out - this is what I have ...which is not bad...but only 80% satisfied
Basically I'd like T2 ,T3, DP and AP Removed, and T1 to be larger and labelled "Tank Temp.
// Autogenerated file by RAGen (v1.1.0.126), (02/18/2012 12:20)
// RA_021212_1220.pde
#define SIMPLE_MENU
#define AI_LED
#define DisplayLEDPWM
#define DateTimeSetup
#define ATOSetup
#define SingleATOSetup
#define CUSTOM_MAIN
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_AI.h>
byte x,y;
ReefAngel.LCD.Clear(BtnActiveColor,5,0,127,11);
ReefAngel.LCD.DrawText(DefaultBGColor,BtnActiveColor,30,3,"PepsiMan's Reef");
ReefAngel.LCD.DrawDate(6, 122);
ReefAngel.LCD.DrawMonitor(15, 15, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 15, ReefAngel.Params);
ReefAngel.LCD.Clear(DefaultFGColor,5,52,127,52);
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,15,55,"AI Sol Blue LED");
x=15;
y=68;
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x,y,"W
ConvertNumToString(text, ReefAngel.AI.GetChannel(White), 1);
strcat(text," ");
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x+74,y,text);
y+=10;
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x,y,"Blue:");
ConvertNumToString(text, ReefAngel.AI.GetChannel(Blue), 1);
strcat(text," ");
y+=10;
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x,y,"Royal Blue:");
ConvertNumToString(text, ReefAngel.AI.GetChannel(RoyalBlue), 1);
strcat(text," ");
y+=10;
ReefAngel.LCD.DrawOutletBox(12, 103, TempRelay);
ReefAngel.AI.SetPort(highATOPin);
ReefAngel.FeedingModePorts = B11001000;
ReefAngel.WaterChangePorts = B11001000;
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.AI.SetChannel(White,35);
ReefAngel.AI.SetChannel(Blue,20);
ReefAngel.AI.SetChannel(RoyalBlue,40);
ReefAngel.SingleATO(true,Port1,30,8);
ReefAngel.StandardHeater(Port3);
ReefAngel.StandardLights(Port5);
You just need to delete this:
That will delete all 3 temps, pH and AP, DP.
Then you need to just draw whatever you want in its place.
Read the custom main manual:
