ATO code correct?
miked
ATO code correct?
Post by miked »
here is the code. I am reinstalling it due to issues. please look at my ATO set up and verify that it is set up as a high and high/high backup to turn off power to port 5.
thanks, oh and dont mind the PWM error, I manually fixed it after posting code.
// Autogenerated file by RAGen (v1.2.1.158), (03/08/2012 19:22)
// RA_030812_1922.ino
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define SaveRelayState
#define SIMPLE_MENU
#define PWMEXPANSION
#define ENABLE_ATO_LOGGING
#define ENABLE_EXCEED_FLAGS
    ReefAngel.FeedingModePorts = Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port4Bit;
    ReefAngel.Relay.On(Port6);
    ReefAngel.Relay.On(Port7);
    ReefAngel.Relay.On(Port8);
    // Specific functions
    ReefAngel.StandardLights(Port1);
    ReefAngel.MHLights(Port3);
    ReefAngel.StandardHeater(Port4);
    ReefAngel.StandardATO(Port5);
    ReefAngel.Relay.Set(Port5,!ReefAngel.HighATO.IsActive());
    ReefAngel.PWM.ActinicPWMSlope(10,0,23,0,5,75,180,5);
    ReefAngel.PWM.DaylightPWMSlope(11,0,21,0,5,65,120,5);
    ReefAngel.Portal("miked", " :lol: ");
Re: ATO code correct?
Change this:
To this:
    ReefAngel.SingleATO(Port5);
miked
Post by miked »
rimai wrote:Change this:
To this:
