ive upload this in my memory
// Autogenerated file by RAGen (v1.2.1.158), (03/11/2012 21:13)
// Memory_031112_2113.ino
// This file sets the default values to the Internal Memory
#include <avr/pgmspace.h>
RA_NokiaLCD e;
e.Init();
e.BacklightOn();
InternalMemory.MHOnHour_write(14);
InternalMemory.MHOnMinute_write(0);
InternalMemory.MHOffHour_write(0);
InternalMemory.MHOffMinute_write(0);
InternalMemory.MHDelay_write(3);
InternalMemory.StdLightsOnHour_write(2);
InternalMemory.StdLightsOffHour_write(0);
InternalMemory.StdLightsOffMinute_write(0);
InternalMemory.DP1Timer_write(10);
InternalMemory.DP1RepeatInterval_write(60);
InternalMemory.DP2RepeatInterval_write(60);
InternalMemory.ATOTimeout_write(60);
InternalMemory.ATOHighTimeout_write(60);
InternalMemory.LEDPWMActinic_write(100);
InternalMemory.LEDPWMDaylight_write(100);
InternalMemory.WM1Timer_write(200);
InternalMemory.WM2Timer_write(354);
InternalMemory.HeaterTempOn_write(780);
InternalMemory.HeaterTempOff_write(791);
InternalMemory.ChillerTempOn_write(810);
InternalMemory.ChillerTempOff_write(785);
InternalMemory.PHMax_write(840);
InternalMemory.PHMin_write(550);
InternalMemory.SalMax_write(2550);
InternalMemory.RFMode_write(Constant);
InternalMemory.RFSpeed_write(140);
InternalMemory.RFDuration_write(8);
InternalMemory.PWMSlopeStartD_write(15);
InternalMemory.PWMSlopeEndD_write(128);
InternalMemory.PWMSlopeDurationD_write(60);
InternalMemory.PWMSlopeStartA_write(15);
InternalMemory.PWMSlopeEndA_write(128);
InternalMemory.PWMSlopeDurationA_write(60);
// display success screen
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*2, "Internal Memory Set");
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*4, "Now load your");
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, " RA code file");
delay(5000);
// Autogenerated file by RAGen (v1.2.1.158), (03/11/2012 21:21)
// RA_031112_2121.ino
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.Relay.DelayedOn(Port3, 2);
ReefAngel.StandardLights(Port5);
ReefAngel.StandardLights(Port6);
ReefAngel.PWM.SetActinic(PWMSlope(14,00,0,30,15,100, 60, ReefAngel.PWM.GetActinicValue() ));
ReefAngel.PWM.SetDaylight(PWMSlope(14,30,0,00,15,90, 60, ReefAngel.PWM.GetDaylightValue() ));
// accensione pompa dx grande dalle 15:00 alle 0:00
if (((NumMins(hour(),minute()) >= NumMins(15,00)) && (NumMins(hour(),minute()) <= NumMins(23,59))) )ReefAngel.Relay.On(Port7); else ReefAngel.Relay.Off(Port7);
// accensione pompa dx piccola dalle 0:00 alle 14:43 e dalle 15:00 alle 21:15
if (((NumMins(hour(),minute()) >= NumMins(0,00)) && (NumMins(hour(),minute()) <= NumMins(14,43))) || (NumMins(hour(),minute()) >= NumMins(15,00)) && (NumMins(hour(),minute()) <= NumMins(21,15))) ReefAngel.Relay.On(Port8); else ReefAngel.Relay.Off(Port8);
This morning at 8.00 ive found my light on at 57% instead they would have been off!!
what is the error?
thx and bye
