Problem with ATO timeout or Overheat
Re: Problem with ATO timeout or Overheat
I've made a change on the libraries not too long ago. Can you try updating it and let me know if you still have this issues?
OK, updated libraries on Friday, as of now (monday morning), no Overheat alarms...and the "max temp" code you sent me is still on, it is reporting the real max temp, like 81 or whatever, not the "spike" temps of 2900 degrees, so it seems problem is solved for now...thanks
