// Autogenerated file by RAGen (v1.2.1.158), (03/18/2012 10:21)
// RA_031812_1021.ino
#define DateTimeSetup
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 4
#include <avr/pgmspace.h>
prog_char id_label[] PROGMEM = "jgriffith";
prog_char probe1_label[] PROGMEM = "water";
prog_char probe2_label[] PROGMEM = "room";
prog_char probe3_label[] PROGMEM = "lights";
prog_char relay1_label[] PROGMEM = "lights";
prog_char relay2_label[] PROGMEM = "actinic";
prog_char relay3_label[] PROGMEM = "high noon";
prog_char relay4_label[] PROGMEM = "moon lights";
prog_char relay5_label[] PROGMEM = "fuge lights";
prog_char relay6_label[] PROGMEM = "dosing pump";
prog_char relay7_label[] PROGMEM = "ato";
prog_char relay8_label[] PROGMEM = "heater";
relay3_label, relay4_label, relay5_label, relay6_label, relay7_label, relay8_label};
// Initialize and start the timer
ReefAngel.Timer[4].SetInterval(60); // set interval to 180 seconds
ReefAngel.Timer[4].Start();
// Specific functions
ReefAngel.StandardLights(Port1);
ReefAngel.MHLights(Port3); // Uses MHLights schedule for high noon lights
ReefAngel.StandardLights(Port4,120); // Offset 120 minutes from Port1
ReefAngel.MoonLights(Port5); // Inverse cycle of Port1
ReefAngel.DosingPump1(Port6);
ReefAngel.StandardATO(Port7);
ReefAngel.StandardHeater(Port8);
ReefAngel.PWM.SetActinic(PWMSlope(10,0,22,0,15,55,120,15));
ReefAngel.PWM.SetDaylight(PWMSlope(11,0,21,0,15,55,120,15));
if ( ReefAngel.Timer[4].IsTriggered() )
ReefAngel.WebBanner();
error compiling
jgriffith
error compiling
I just changed my pde to enable web banners (or at least tried to:)). Not sure what happened, but i now have an error compiling when I try to upload.
Re: error compiling
The WebBanner() function was replaced with the Portal() function.
Use this instead:
Use this instead:
#define VersionMenu
#define wifi
#define WDT
#define CUSTOM_MENU
ReefAngel.Portal("jgriffith");
jgriffith
Re: error compiling
So I made it way too complicated? All I had to add from my previous code was that last part "ReefAngel.Portal ("jgriffith");"?
Re: error compiling
yeap
That's the controller ever evolving
Before you used to have to do all that to get the banner.
Now, just add the Portal() function.
jgriffith
Re: error compiling
Nice, thanks once again for your help!
I just noticed that on my portal it shows my moonlights still on, the mainlights are now on, according to the above code shouldnt they be offnow? Port 4 should be moonlights, port 5 says moonlights but those are fuge and appear to be correct (reverse cycle)
jgriffith
Re: error compiling
I am now gettig errors unable to rename 'core.a'; reason Permission denied
I just went back to a previous code and added the portal function, looks good, time to upload
jgriffith
Re: error compiling
I just uploaded the following code and the webbanner has not updated, I also can't see charts in the portal, am I missing something?
Edit, it works now...I guess I'm impatient
I think the only thing I need to fix is the moonlights on Port 4, I would like them on 2 hours b/f and after the main lights (port 1)
// Autogenerated file by RAGen (v1.2.1.158), (03/18/2012 10:17)
// RA_031812_1017.ino
#define VersionMenu
#define wifi
#define WDT
#define CUSTOM_MENU
prog_char menu0_label[] PROGMEM = "Item 1";
prog_char menu1_label[] PROGMEM = "Item 2";
prog_char menu2_label[] PROGMEM = "Item 3";
prog_char menu3_label[] PROGMEM = "Item 4";
menu0_label, menu1_label, menu2_label, menu3_label };
void MenuEntry1()
ReefAngel.DisplayMenuEntry("Item 1");
void MenuEntry2()
ReefAngel.DisplayMenuEntry("Item 2");
void MenuEntry3()
ReefAngel.DisplayMenuEntry("Item 3");
void MenuEntry4()
ReefAngel.DisplayMenuEntry("Item 4");
ReefAngel.MHLights(Port3); //Uses MHLights schedule for high noon lights
ReefAngel.StandardLights(Port4,120); // Offsets 120 minutes from Port1
ReefAngel.MoonLights(Port5); //Inverse cycle of Port1
jgriffith
Re: error compiling
Anyone know how I can code port 4 to come on 2 hours before port 1, turn off when port 1 is on, then come on when port 1 is off for 2 hours, then off?
Re: error compiling
Right now, they are already turning on and off with 2hour offset, right?
You just want to have them turn off when port 1 is on, correct?
jgriffith
Re: error compiling
Yes, although I guess its not that big of a deal to leave them on, the leds are going to last forever anyways.
Re: error compiling
Ok, so if all you want to do is turn them off whe Port1 is on, try this:
Add it just below this:
if (ReefAngel.Relay.Status(Port1)) ReefAngel.Relay.Off(Port4);
jgriffith
