Heya Guys,
I'm wanting to control a relay being triggered on and off depending on the ORP value. Is there an inbuilt method to do this? I had a squiz but can't see much for Orp, mainly just PH and CO2.
ORP Control
Re: ORP Control
No. You need to create your own, like this:
if (ReefAngel.Params.ORP>0 && ReefAngel.Params.ORP<350) ReefAngel.Relay.On(Port1);
if (ReefAngel.Params.ORP>430) ReefAngel.Relay.Off(Port1);
egadgetjnr
Re: ORP Control
Thanks Roberto,rimai wrote:No. You need to create your own, like this:Code: Select all
if (ReefAngel.Params.ORP>0 && ReefAngel.Params.ORP<350) ReefAngel.Relay.On(Port1); if (ReefAngel.Params.ORP>430) ReefAngel.Relay.Off(Port1);
I thought that might have been the case so I did something similar.
I noticed that there was a Global Memory entry called Mem_I_ORPMax and ORPMin, are they created for this purpose and can you change them in the portal?
