    #include <DS1307RTC.h>fafa
    #include <RF.h>fa
      byte myRFMode=0;
        byte myRFDuration=0;
        byte myRFSpeed=0;
    ReefAngel.WaterChangePorts = Port1Bit | Port8Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
      ReefAngel.FeedingModePorts = Port1Bit | Port6Bit | Port8Bit; // Turn off Ports 1, 6, 7 and 8 when Water Change Mode is activated
      ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit| Port5Bit;
      ReefAngel.OverheatShutoffPorts = Port2Bit |Port3Bit | Port4Bit | Port5Bit | Port7Bit; // Turn off Ports 3,
        ReefAngel.Relay.On( Box1_Port2 );  // Razor Led
        ReefAngel.Relay.On( Box1_Port4 ); // Sump Equipment - UV, Pump
        ReefAngel.Relay.On( Box1_Port5 ); // MP40s
        ReefAngel.Relay.On( Box1_Port6 ); // JBJ
      //  Port1 Return pump...  on all the time!!!
          ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port4 ) ); //Refuge
      //  Port3 ...  not used
          ReefAngel.StandardLights( Port4,10,0,20,0 ); //ATI Actinic
          ReefAngel.StandardLights( Port5,11,0,19,0 );  //ATI Daylight
          ReefAngel.StandardLights( Port6,10,0,20,0 );  //ATI Fan
          ReefAngel.StandardHeater( Port7,778,790 ); //Heater
          ReefAngel.Relay.DelayedOn( Port8,2 ); //Skimmer
          //box 2
          ReefAngel.Relay.Off( Box1_Port1); // Lunar Hub Not used   Port #9
    //   Box1_Port2 Razor_LED (Sump)...  on all the time!!!      Port #10
          ReefAngel.Relay.Off( Box1_Port3); // Start with the relay off       Port #11
                  if (hour()>=5 && hour()<10) ReefAngel.Relay.On(Box1_Port3); // Moonlight Between 5-10am turn the relay on
                  if (hour()>=20 && hour()<=23) ReefAngel.Relay.On(Box1_Port3); // From 8pm-Midnight turn the relay on
    //   Box1_Port4 Ecotech MP_40 Pumps  on all the time!!!      Port #12
    //   Box1_Port5 Razor_LED (Sump)...  on all the time!!!      Port #13
    //   Box1_Port6 JBJ ATO ...          on all the time!!!      Port #14
         ReefAngel.Relay.Off( Box1_Port7);  // ALK Doser ...      Port #15
         ReefAngel.Relay.Off( Box1_Port8);  // Calc Doser ...     Port #16
    // ReefAngel.PWM.SetDaylight(PWMParabola(20,0,23,0,0, MoonPhase(),0 ));
        ReefAngel.RF.SetMode( ReefCrest,85,10 );
          if (hour()>=6 && hour()<11)
            myRFSetMode(ReefCrest,85,10);
          else if (hour()>=11 && hour()<13)
          else if (hour()>=13 && hour()<16)
            myRFSetMode(Smart_NTM,85,15);
          else if (hour()>=16 && hour()<19)
            myRFSetMode(ReefCrest,65,10);
            myRFSetMode(Lagoon,40,10);
        // Hardcode PH calibrations
         //ReefAngel.PHMin=544; // PH7.0
         //ReefAngel.PHMax=830; // PH10.0
         RunDosingPumps();
         LogDosingPumps();
        ReefAngel.Portal( "ecam" );
        // Parameters
        ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
        ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
        // Main Relay Box
        // Date and Time
    // Define Your dosing pumps
    #define numDPumps 2
    byte pumpRelays[numDPumps]={ Box1_Port7, Box1_Port8 };
    int DPVolume[numDPumps]={ 3, 3 } ; // 1ml for each alk and calcium
    int DPRepeat[numDPumps]={ 240, 240 } ; // Repeat every 4 hrs 5x a day
    // Define Calibration here
    int CalTime[numDPumps]={ 600, 600 }; // 10 minutes / 10 minutes
    int CalVol[numDPumps]={ 350, 300 }; // 350ml / 300ml... .58 / .5
    // Function: RunDosingPumps()
    void RunDosingPumps() {
      float rate;
      int calcTime[numDPumps];
      for (int i=0;i < numDPumps; i++) {
        rate=(float)CalVol[i]/CalTime[i];
        calcTime[i]=DPVolume[i]/rate/(1440/DPRepeat[i]);
        // Run the pumps
        ReefAngel.DosingPumpRepeat(pumpRelays[i], i*20, DPRepeat[i], calcTime[i]); // Offset between each pump is 20 minutes
      // Display Time calculated in portal
      ReefAngel.CustomVar[0]=calcTime[0];
      ReefAngel.CustomVar[1]=calcTime[1];
    // Function: LogDosingPumps()
    void LogDosingPumps() {
      static time_t pumpTimer[numDPumps];
      static boolean pumpStatus[numDPumps];
      float rate;
      for (int i=0;i< numDPumps;i++) {
        if (ReefAngel.Relay.Status(pumpRelays[i])) {
          if (!pumpStatus[i]) {
            pumpStatus[i]=true;
        } else {
          if (pumpStatus[i]) {
            pumpStatus[i]=false;
            // Report How much volume has been dosed per day.
            // Could make this in minutes... excercise for the reader..
            ReefAngel.CustomVar[2]=pumpTimer[0]*rate;
            ReefAngel.CustomVar[3]=pumpTimer[1]*rate;
        // Clear timer at end of day
        if (now()%SECS_PER_DAY==SECS_PER_DAY-1) pumpTimer[i]=0;
        void myRFSetMode(byte m, byte s, byte d)
          if (m!=myRFMode || s!=myRFSpeed || d!=myRFDuration || millis()<5000)
            myRFMode=m;
            myRFSpeed=s;
            myRFDuration=d;
            ReefAngel.RF.SetMode(m,s,d);
