Auto Water Change Code
WIReefer83
Hello - I'm trying to code an auto water change for my reef tank and my fish qt tank. I have all the code written based on what I've read here in the forum. For some reason, when I manually select Water Change Mode on the RA, nothing happens. Any ideas?
byte wc_status = -2;
ReefAngel.AddMultiChannelWaterLevelExpansion(); // Multi-Channel Water Level Expanion Module
ReefAngel.FeedingModePorts = Port2Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.CustomLabels[0]="LEDs";
ReefAngel.CustomLabels[1]="Skimmer";
ReefAngel.CustomLabels[2]="SumpToFishQT";
ReefAngel.CustomLabels[3]="SumpDrain";
ReefAngel.CustomLabels[4]="Wave R";
ReefAngel.CustomLabels[5]="Wave L";
ReefAngel.CustomLabels[6]="Heaters";
ReefAngel.CustomLabels[7]="Constant";
ReefAngel.CustomLabels[8]="SumpATO";
ReefAngel.CustomLabels[9]="FishQTATO";
ReefAngel.CustomLabels[10]="FishQTDrain";
ReefAngel.CustomLabels[11]="SaltToSump";
ReefAngel.StandardLights( Port1,16,0,22,0 );
ReefAngel.Relay.DelayedOn( Port2,5 );
ReefAngel.WavemakerRandom( Port5,60,100 );
ReefAngel.WavemakerRandom( Port6,60,100 );
//ReefAngel.Relay.Set( Port6, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.StandardHeater( Port7,775,785 );
ReefAngel.PWM.SetChannel( 3, PWMParabola(16,0,22,0,10,50,10) );
ReefAngel.PWM.SetChannel( 4, PWMParabola(16,0,22,0,10,50,10) );
ReefAngel.PWM.SetChannel( 5, PWMParabola(16,0,22,0,10,50,10) );
//ATO For Main Sump
if (hour()==19 && minute()==0) //Only run ATO between 7:00pm and 7:01pm daily
if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) ReefAngel.Relay.Off(Box1_Port1); //don't run ATO during a water change
if (ReefAngel.WaterLevel.GetLevel(1)<=70 && ReefAngel.DisplayedMenu != WATERCHANGE_MODE) ReefAngel.Relay.On(Box1_Port1);
if (ReefAngel.WaterLevel.GetLevel(1)>=80) ReefAngel.Relay.Off(Box1_Port1);
//ATO For Fish QT
if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) ReefAngel.Relay.Off(Box1_Port2); //don't run ATO during a water change
if (ReefAngel.WaterLevel.GetLevel(3)<=80 && ReefAngel.DisplayedMenu != WATERCHANGE_MODE) ReefAngel.Relay.On(Box1_Port2);
if (ReefAngel.WaterLevel.GetLevel(3)>=90) ReefAngel.Relay.Off(Box1_Port2);
// EMERGENCY SUMP WATER LEVEL BELOW 20% AND WATERCHANGE MODE IS NOT ON AND WAIT FOR CONTROLLER TO BE ON FOR 5 SECONDS
if ( ReefAngel.WaterLevel.GetLevel(1) <= 20 && ReefAngel.DisplayedMenu!=WATERCHANGE_MODE && millis() > 5000)
ReefAngel.Relay.Off(Port8); //Turn off return pumps
//Water Change Process
if(ReefAngel.DisplayedMenu!=WATERCHANGE_MODE && wc_status != -2) wc_status = -2;
//-2 - Top Off Sump
if(ReefAngel.DisplayedMenu==WATERCHANGE_MODE && wc_status == -2)
if( ReefAngel.WaterLevel.GetLevel(1)<80) ReefAngel.Relay.On(Box1_Port1);
if( ReefAngel.WaterLevel.GetLevel(1)>=80) ReefAngel.Relay.Off(Box1_Port1);
if( ReefAngel.WaterLevel.GetLevel(1)>=80) wc_status = -1;
//-1 - Top Off FishQT
if(ReefAngel.DisplayedMenu==WATERCHANGE_MODE && wc_status == -1)
if( ReefAngel.WaterLevel.GetLevel(3)<90) ReefAngel.Relay.On(Box1_Port2);
if( ReefAngel.WaterLevel.GetLevel(3)>=90) ReefAngel.Relay.Off(Box1_Port2);
if( ReefAngel.WaterLevel.GetLevel(3)>=90) wc_status = 0;
//0 - Drain FishQT Tank
if(ReefAngel.DisplayedMenu==WATERCHANGE_MODE && wc_status == 0)
if( ReefAngel.WaterLevel.GetLevel(3)>85) ReefAngel.Relay.On(Box1_Port3);
if( ReefAngel.WaterLevel.GetLevel(3)<=85) ReefAngel.Relay.Off(Box1_Port3);
if( ReefAngel.WaterLevel.GetLevel(3)<=85) wc_status = 1;
//1 - Fill FishQT From Sump
if(ReefAngel.DisplayedMenu==WATERCHANGE_MODE && wc_status == 1)
if( ReefAngel.WaterLevel.GetLevel(3)<90) ReefAngel.Relay.On(Port3);
if( ReefAngel.WaterLevel.GetLevel(3)>=90) ReefAngel.Relay.Off(Port3);
if( ReefAngel.WaterLevel.GetLevel(3)>=90) wc_status = 2;
//2 - Drain Sump To Floor Drain
if(ReefAngel.DisplayedMenu==WATERCHANGE_MODE && wc_status == 2)
if( ReefAngel.WaterLevel.GetLevel(2)>75) ReefAngel.Relay.On(Port4);
if( ReefAngel.WaterLevel.GetLevel(2)<=75) ReefAngel.Relay.Off(Port4);
if( ReefAngel.WaterLevel.GetLevel(2)<=75) wc_status = 3;
//3 - Fill Sump With Fresh Saltwater
if(ReefAngel.DisplayedMenu==WATERCHANGE_MODE && wc_status == 3)
if( ReefAngel.WaterLevel.GetLevel(2)<80) ReefAngel.Relay.On(Box1_Port3);
if( ReefAngel.WaterLevel.GetLevel(2)>=80 && ReefAngel.WaterLevel.GetLevel(1)>=80) ReefAngel.Relay.Off(Box1_Port3);
if( ReefAngel.WaterLevel.GetLevel(2)>=80 && ReefAngel.WaterLevel.GetLevel(1)>=80) ButtonPress++;
//Water Change Complete
//ATO For Main Sump
//ATO For Fish QT
//-2 - Top Off Sump
WIReefer83
Re: Auto Water Change Code
Part of the problem is that byte values cannot be negative. Fixed that, then the water change process initiated, but after step 1, it exited water change mode.
byte wc_status = 0;
//ATO For Main Sump
//ATO For Fish QT
// Emergency Sump Low Check
if(ReefAngel.DisplayedMenu!=WATERCHANGE_MODE && wc_status != 0) wc_status = 0;
//0 - Top Off Sump
if( ReefAngel.WaterLevel.GetLevel(1)>=80) wc_status = 1;
//1 - Top Off FishQT
//2 - Drain FishQT Tank
if( ReefAngel.WaterLevel.GetLevel(3)<=85) wc_status = 3;
//3 - Fill FishQT From Sump
if( ReefAngel.WaterLevel.GetLevel(3)>=90) wc_status = 4;
//4 - Drain Sump To Floor Drain
if(ReefAngel.DisplayedMenu==WATERCHANGE_MODE && wc_status == 4)
if( ReefAngel.WaterLevel.GetLevel(2)<=75) wc_status = 5;
//5 - Fill Sump With Fresh Saltwater
if(ReefAngel.DisplayedMenu==WATERCHANGE_MODE && wc_status == 5)
byte wc_status = 0;
//ATO For Main Sump
//ATO For Fish QT
//0 - Top Off Sump
You need to try some debugging code (Serial.println) and see what the values are and monitor in Serial Monitor. The code looks ok but need to watch whats going on...
WIReefer83
Keeping my RA connected to my PC was causing my issues. Working as expected now! Thx
WIReefer83
I'd like to add a feature in my auto water change code that I haven't come across yet in the forum posts. After the step where I drain my sump, I'd like the process to pause, so I can manually clean my sump while there is no water. Then, once I'm finished, I'd like to click the button on the RA to resume the rest of the water change process. Is this possible?
Yeah we can do that. Is the code above recent?
Does it have to be a button on the RA cause your in waterchange mode and that would cancel. If you have wifi we can use either a free relay outlet or start a new relay box with "virtual" ports that we can use as a trigger
WIReefer83
I don't have the wifi module yet, but plan to get it soon. Sounds like I will need to wait since the button press will exit out of the water change mode. I will post my current code once I get the wifi module (code above is out of date). Thx
It may still be possible. Maybe roberto has an idea. Or we could process joystick moves? I'm sure something could be figured out. The wifi makes it easy and we could add up to 8 or 12 expansion hubs that don't exist to use for macros or what not.
Try this. It will wait for a joystick up movement before moving to the fill stage
byte wc_status = 0;
//ATO For Main Sump
//ATO For Fish QT
//0 - Top Off Sump
//5 - Wait for Joystick Move
if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE && wc_status == 5)
if (ReefAngel.Joystick.IsUp()) wc_status=6;
//6 - Fill Sump With Fresh Saltwater
if(ReefAngel.DisplayedMenu==WATERCHANGE_MODE && wc_status == 6)
