Dimming channel 3 on 3 times in 1 day?
PostPosted: Tue Nov 14, 2017 1:59 pm
I have my DIY rapid LEDs connected to my dimming module on channel 3.
Currently it goes on at 12pm - 9pm and does it's dimming cycle. from 0%-90%
I'd like it to also go on at 1% from 9pm to Midnight, and from 6am-12pm.
This way I can check on my frag tank in the morning. Is this possible?
PostPosted: Tue Nov 14, 2017 2:12 pm
Yes, can you post your code?
PostPosted: Tue Nov 14, 2017 2:29 pm
    ReefAngel.FeedingModePorts = Port1Bit;
    ReefAngel.WaterChangePorts = Port1Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardHeater( Port3,770,780 );
    ReefAngel.StandardLights( Port5,12,0,21,0 );
    ReefAngel.StandardLights( Port6,21,0,12,0 );
    ReefAngel.StandardHeater( Box1_Port3,770,780 );
    ReefAngel.StandardHeater( Box1_Port5,770,780 );
    ReefAngel.StandardATO( Box1_Port6,60 );
    ReefAngel.StandardLights( Box1_Port7,21,30,16,30 );
    ReefAngel.PWM.SetChannel( 1, PWMSlope(20,45,13,15,0,50,60,0) );
    ReefAngel.PWM.SetChannel( 2, PWMSlope(20,45,13,15,0,50,60,0) );
    ReefAngel.PWM.SetChannel( 3, PWMSlope(12,0,21,0,0,24,60,0) );
    ReefAngel.PWM.SetChannel( 4, PWMSlope(12,0,21,0,0,80,60,0) );
    ReefAngel.DCPump.SetMode( ReefCrest,35,10 );
    ReefAngel.DCPump.ExpansionChannel[0] = Sync;
    ReefAngel.Portal( "GugsJr" );
    ReefAngel.DDNS( "Home" ); // Your DDNS is GugsJr-Home.myreefangel.com
PostPosted: Tue Nov 14, 2017 7:14 pm
Try this:
ReefAngel.PWM.SetChannel( 3, PWMSlope(12,0,21,0,0,24,60,1) );
if (hour()<6) ReefAngel.PWM.SetChannel( 3, 0);
The one at the end of the slope function is what it will be at the end of the slope instead of 0%. Then you set the channel to zero from midnight to 6am.
PostPosted: Thu Nov 16, 2017 11:49 pm
didn't work, ended up getting it to work with this
if (hour()>=12 && hour()<=21) ReefAngel.PWM.SetChannel( 4, PWMSlope(12,0,21,0,0,100,60,0) );
 else if (hour()>=6 && hour()<=12) ReefAngel.PWM.SetChannel( 4, 3);
 else if (hour()>=21 && hour()<24) ReefAngel.PWM.SetChannel( 4, 3);
 else if (hour()>=0 && hour()<=1) ReefAngel.PWM.SetChannel( 4, 3);
 else if (hour()>=1 && hour()<=6) ReefAngel.PWM.SetChannel( 4, 0);
Return to How do I code ...
