Lightsoverride error when using Wizard
Ask in here.
PostPosted: Tue May 15, 2018 11:44 am
I'm using the Wizard to refresh my code but it won't compile! My setup is relatively simple, I am programming the relay plus an AISOL in the Low port. Compiling gives me a Lightsoverride error. I searched through all the forum and from a topic related to a Jebeo I tried a the few lines of code they suggested, but none of those changes would allow my wizard-generated code to compile. I welcome any suggestions. Here's a copy of my code produced by the Wizard (less my portal information):
ReefAngel.FeedingModePorts = Port3Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port8Bit;
// Setup ATO Port for AI communication
ReefAngel.AI.SetPort( lowATOPin );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardFan( Port3,780,810 );
ReefAngel.CO2Control( Port5,620,670 );
ReefAngel.StandardLights( Port7,20,0,8,0 );
ReefAngel.AI.SetChannel( White, PWMParabola(9,0,20,0,15,100,15) );
ReefAngel.AI.SetChannel( Blue, PWMParabola(9,0,20,0,15,100,15) );
ReefAngel.AI.SetChannel( RoyalBlue, PWMParabola(9,0,20,0,15,100,15) );
//ReefAngel.Portal( "stolat01" );
// ReefAngel.DDNS( "00.00.00.00" ); //
PostPosted: Thu May 17, 2018 9:52 am
I just checked this and indeed it is a problem in the libraries.
Simply add this anywhere in the code:
//ReefAngel.PWM.
It is going to enable PWM without adding anything to your code, but PWM is required.
PostPosted: Thu May 17, 2018 10:51 am
That did it. Thanks!
Return to How do I code ...
Users browsing this forum: No registered users and 5 guests
