RA* Unable to Update via Remote Upload
PostPosted: Fri Jul 20, 2018 12:39 pm
I've got my RA* up and running with the exception of being able to update the code via Remote Upload through the wizard.
    The unit is showing connected to the cloud
    I'm able to check the status and turn ports on/off through uapp
    If I connect via a com port on my PC I can upload code
Any thoughts?
Here's my code:
    ReefAngel.Star();
    ReefAngel.FeedingModePortsE[0] = Port2Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[1] = 0;
    ReefAngel.OverheatShutoffPortsE[0] = Port4Bit | Port6Bit;
    ReefAngel.DosingPumpRepeat( Box1_Port1,0,60,83 );//Alk
    ReefAngel.SingleATO( true,Box1_Port2,1000,0 );//ATO
    ReefAngel.DosingPumpRepeat( Box1_Port3,30,60,82 );//Cal
    ReefAngel.StandardHeater( T1_PROBE,Box1_Port4,780,785 );
    ReefAngel.StandardLights( Box1_Port6,12,0,19,0 ); //T5
    ReefAngel.StandardLights( Box1_Port7,23,0,6,0 ); //Refugium Lights
    ReefAngel.PWM.SetDaylight( PWMSlope( 9,0,17,0,15,70,60,0 ) );
    ReefAngel.PWM.SetActinic( PWMSlope( 9,0,17,0,15,70,60,0 ) );
    ReefAngel.PWM.SetDaylight2( PWMSlope( 9,0,17,0,15,70,60,0 ) );
    ReefAngel.PWM.SetActinic2( PWMSlope( 9,0,17,0,15,70,60,0 ) );
    ReefAngel.DCPump.SetMode( LongPulse,80,60000 );
    ReefAngel.DCPump.Daylight2Channel = AntiSync;
    ReefAngel.DCPump.Actinic2Channel = None;
    boolean buzzer=false;
    if ( ReefAngel.isATOTimeOut() ) buzzer=true;
    if ( ReefAngel.isOverheat() ) buzzer=true;
    static unsigned long feeding;
    //feeding mode nutrient transport time
    if (now()-feeding<3600) {
        ReefAngel.DCPump.SetMode(NutrientTransport,100,4000);
    //vacation mode
    if (hour()==17 && minute()==0 && second()==0)
        ReefAngel.FeedingModeStart();
    if (hour() > 21 || hour() < 7)
        ReefAngel.DCPump.SetMode( Lagoon,60,10 );
    if (hour() >= 8 || ReefAngel.Params.PH > 860)
        ReefAngel.Relay.Off (Box1_Port1);
        ReefAngel.Relay.Off (Box1_Port3);
    ReefAngel.Network.Cloud();
PostPosted: Sun Jul 22, 2018 9:48 pm
This code seems to be missing something at the end.
PostPosted: Mon Jul 23, 2018 4:58 pm
I didn’t paste the commented out code that includes the encrypted password. Is that what you meant?
PostPosted: Mon Jul 23, 2018 5:32 pm
Yes. I just wanted to make sure they were there
PostPosted: Mon Sep 10, 2018 5:36 pm
Checking back in to see if anyone has ideas on this. I'm still unable to upload remotely. Not sure if something is going on with the unit as I see what looks like a download message periodically (see image below). It is not there all the time, but when it is, always says 1%.
PostPosted: Mon Sep 10, 2018 9:56 pm
Not sure why it is not downloading for you.
I just tested this and it worked.
PostPosted: Tue Sep 11, 2018 9:40 am
Any other thought out there? It’s not only frustrating that I can’t remote upload, but can’t receive alerts either
Is there anything with my router that I should be looking at?
PostPosted: Tue Sep 11, 2018 10:27 am
Connect to your computer and use Arduino to get the serial monitor log.
PostPosted: Tue Sep 11, 2018 5:15 pm
Here is what I get:
10.0.0.23
Portal Call
MQTT Connecting...
MQTT failed
Disconnected
Connecting...
10.0.0.23
Connected
HTTP/1.1 200 OK
Content-Type: text/html; charset=UTF-8
Server: Microsoft-IIS/8.5
X-Powered-By: PHP/5.6.24
Date: Wed, 12 Sep 2018 00:14:32 GMT
Connection: close
Content-Length: 0
Data: 0
Header: 0
Disconnected
MQTT Connecting...
MQTT succeeded
PostPosted: Tue Sep 11, 2018 5:21 pm
I don't think your controller is configured correctly.
If you browse to http://10.0.0.23:2000/r99 , what do you get?
Next
Return to How do I code ...
Users browsing this forum: Google [Bot] and 2 guests
