<RA>
<ID>ReefingHavoc</ID>
<T1>0</T1>
<T2>0</T2>
<T3>0</T3>
<PH>852</PH>
<R>0</R>
<RON>0</RON>
<ROFF>255</ROFF>
<R1>144</R1>
<RON1>0</RON1>
<ROFF1>255</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>0</ATOLOW>
<ATOHIGH>0</ATOHIGH>
<EM>1</EM>
<EM1>6</EM1>
<REM>1</REM>
<BID>4</BID>
<AF>0</AF>
<SF>0</SF>
<PWMA>0</PWMA>
<PWMD>80</PWMD>
<PWMAO>255</PWMAO>
<PWMDO>255</PWMDO>
<PWMA2>0</PWMA2>
<PWMD2>0</PWMD2>
<PWMA2O>255</PWMA2O>
<PWMD2O>255</PWMD2O>
<DCM>4</DCM>
<DCS>80</DCS>
<DCD>100</DCD>
<DCT>30</DCT>
<LEAK>0</LEAK>
<ALARM>0</ALARM>
<PWME0>0</PWME0>
<PWME0O>255</PWME0O>
<PWME1>0</PWME1>
<PWME1O>255</PWME1O>
<PWME2>0</PWME2>
<PWME2O>255</PWME2O>
<PWME3>0</PWME3>
<PWME3O>255</PWME3O>
<PWME4>0</PWME4>
<PWME4O>255</PWME4O>
<PWME5>0</PWME5>
<PWME5O>255</PWME5O>
</RA>
RA* Unable to Update via Remote Upload
• Page 2 of 4 • 1, 2, 3, 4
More came through on the monitor:
Portal Call Data Sent HTTP/1.1 200 OK Cache-Control: private Content-Type: text/html; charset=utf-8 Server: Microsoft-IIS/8.5 X-AspNet-Version: 4.0.30319 X-Powered-By: ASP.NET Date: Wed, 12 Sep 2018 00:19:33 GMT Connection: close Content-Length: 4 DoneDisconnected Connecting... Connected HTTP/1.1 200 OK Content-Type: text/html; charset=UTF-8 Server: Microsoft-IIS/8.5 X-Powered-By: PHP/5.6.24 Date: Wed, 12 Sep 2018 00:19:33 GMT Connection: close Content-Length: 0 Data: 0 Header: 0 Disconnected |
Ok, so whatever you did a while ago made the controller connect to the portal.
status/chart.aspx?id=ReefingHavoc&filter=ph You can see that it started sending data about half hour ago. So, you should be able to set your email alerts now. Try doing the remote upload again. Roberto.
Thought I'd close the loop on this. I had my connection running through a patch panel that was connected to a AT&T U-verse router. I did some troubleshooting to determine where the problem was as when I connected the RA* directly to a Netgear router, everything seemed to work. Patch panel and all connections turned out to be fine. Tried running the patch panel to the Netgear instead of U-verse and miraculously I'm able to able to now upload remotely and updates hitting the portal. Strange...
I guess it was too good to be true. I haven't touched the RA* since Sunday, but it looks like it stopped communicating yesterday (see attached)
Any thoughts on what is going on? The unit will connect for short periods of time and all of a sudden stop updating to the portal (still shows connected on the unit). I've tried swapping out power cables, ethernet cables, connecting to different routers, observing traffic through a serial monitor. Just today the unit had a black screen and unresponsive to touch. I had to reboot it by unplugging and when it did, saw that the temperature in the tank dropped by 3 degrees. The RA+ was rock solid for years; not sure why I'm having so many issues.
When you were watching the monitor, what did you get when it was not communicating?
I had it connected to a monitor for a couple hours and did not see issues, but when I plugged it back in to the power supply it stopped updating shortly after. I'll run a monitor on it for 24hrs to see what happens. The problem has been that my tank is in the basement and my PC is on the first floor so I have to disconnect the RA* from my system to monitor. I'll figure out how to keep it connected to the system with monitoring in place. Thanks for the follow up Mike |
I ran the monitor for 24 hours and did capture a 400 error at the time the Portal stopped being updated. Data: 0 Header: 0 Disconnected Portal Call Data Sent HTTP/1.1 200 OK Cache-Control: private Content-Type: text/html; charset=utf-8 Server: Microsoft-IIS/8.5 X-AspNet-Version: 4.0.30319 X-Powered-By: ASP.NET Date: Sun, 23 Sep 2018 14:20:17 GMT - This is the time when Portal last updated Connection: close Content-Length: 4 DoneDisconnected Connecting... Connected HTTP/1.1 200 OK Content-Type: text/html; charset=UTF-8 Server: Microsoft-IIS/8.5 X-Powered-By: PHP/5.6.24 Date: Sun, 23 Sep 2018 14:20:18 GMT Connection: close Content-Length: 0 Data: 0 Header: 0 Disconnected Portal Call Actinic 2Data Sent Actinic 2HTTP/1.1 400 Bad Request Content-Type: text/html; charset=us-ascii Server: Microsoft-HTTPAPI/2.0 Date: Sun, 23 Sep 2018 14:25:18 GMT Connection: close Content-Length: 311 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN""http://www.w3.org/TR/html4/strict.dtd"> <HTML><HEAD><TITLE>Bad Request</TITLE> <META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD> <BODY><h2>Bad Request</h2> <hr><p>HTTP Error 400. The request is badly formed.</p> </BODY></HTML> ÿDisconnected Actinic 2Connecting... Actinic 2Connected Actinic 2HTTP/1.1 400 Bad Request Content-Type: text/html; charset=us-ascii Server: Microsoft-HTTPAPI/2.0 Date: Sun, 23 Sep 2018 14:25:19 GMT Connection: close Content-Length: 339 Data: 339 Actinic 2Header: 0 Actinic 2Disconnected Actinic 2Portal Call Actinic 2Data Sent Actinic 2HTTP/1.1 400 Bad Request Content-Type: text/html; charset=us-ascii Server: Microsoft-HTTPAPI/2.0 Date: Sun, 23 Sep 2018 14:30:19 GMT Connection: close Content-Length: 311 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN""http://www.w3.org/TR/html4/strict.dtd"> <HTML><HEAD><TITLE>Bad Request</TITLE> <META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD> <BODY><h2>Bad Request</h2> <hr><p>HTTP Error 400. The request is badly formed.</p> </BODY></HTML> ÿDisconnected Actinic 2Connecting... Actinic 2Connected Actinic 2HTTP/1.1 400 Bad Request Content-Type: text/html; charset=us-ascii Server: Microsoft-HTTPAPI/2.0 Date: Sun, 23 Sep 2018 14:30:20 GMT Connection: close Content-Length: 339 Data: 339 Actinic 2Header: 0 Actinic 2Disconnected Actinic 2Portal Call Actinic 2Data Sent Actinic 2HTTP/1.1 400 Bad Request Content-Type: text/html; charset=us-ascii Server: Microsoft-HTTPAPI/2.0 Date: Sun, 23 Sep 2018 14:35:20 GMT Connection: close Content-Length: 311 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN""http://www.w3.org/TR/html4/strict.dtd"> <HTML><HEAD><TITLE>Bad Request</TITLE> <META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD> <BODY><h2>Bad Request</h2> <hr><p>HTTP Error 400. The request is badly formed.</p> </BODY></HTML> ÿDisconnected Actinic 2Connecting... Actinic 2Connected Actinic 2HTTP/1.1 400 Bad Request Content-Type: text/html; charset=us-ascii Server: Microsoft-HTTPAPI/2.0 Date: Sun, 23 Sep 2018 14:35:21 GMT Connection: close Content-Length: 339 Data: 339 Actinic 2Header: 0 Actinic 2Disconnected Actinic 2Portal Call Actinic 2Data Sent Actinic 2HTTP/1.1 400 Bad Request Content-Type: text/html; charset=us-ascii Server: Microsoft-HTTPAPI/2.0 Date: Sun, 23 Sep 2018 14:40:21 GMT Connection: close Content-Length: 311 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN""http://www.w3.org/TR/html4/strict.dtd"> <HTML><HEAD><TITLE>Bad Request</TITLE> <META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD> <BODY><h2>Bad Request</h2> <hr><p>HTTP Error 400. The request is badly formed.</p> </BODY></HTML> ÿDisconnected Actinic 2Connecting... Actinic 2Connected Actinic 2HTTP/1.1 400 Bad Request Content-Type: text/html; charset=us-ascii Server: Microsoft-HTTPAPI/2.0 Date: Sun, 23 Sep 2018 14:40:22 GMT Connection: close Content-Length: 339 The 400 error captured repeats until 6 PM EST when I disconnected the monitor |
Any thoughts on the 400 error?
Users browsing this forum: No registered users and 5 guests
