RA* Unable to Update via Remote Upload
PostPosted: Tue Oct 30, 2018 10:31 am
Sorry for the delay.
Yeap, looks like something in your code.
Let's start by adding a few things and seeing if it holds up.
    ReefAngel.Star();
    ReefAngel.FeedingModePortsE[0] = Port2Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[1] = 0;
    ReefAngel.OverheatShutoffPortsE[0] = Port4Bit | Port6Bit;
    ReefAngel.DosingPumpRepeat( Box1_Port1,0,60,83 );//Alk
    ReefAngel.SingleATO( true,Box1_Port2,1000,0 );//ATO
    ReefAngel.DosingPumpRepeat( Box1_Port3,30,60,82 );//Cal
    ReefAngel.StandardHeater( T1_PROBE,Box1_Port4,780,785 );
    ReefAngel.StandardLights( Box1_Port6,12,0,19,0 ); //T5
    ReefAngel.StandardLights( Box1_Port7,23,0,6,0 ); //Refugium Lights
    ReefAngel.PWM.SetDaylight( PWMSlope( 9,0,17,0,15,70,60,0 ) );
    ReefAngel.PWM.SetActinic( PWMSlope( 9,0,17,0,15,70,60,0 ) );
    ReefAngel.PWM.SetDaylight2( PWMSlope( 9,0,17,0,15,70,60,0 ) );
    ReefAngel.PWM.SetActinic2( PWMSlope( 9,0,17,0,15,70,60,0 ) );
    boolean buzzer=false;
    if ( ReefAngel.isATOTimeOut() ) buzzer=true;
    if ( ReefAngel.isOverheat() ) buzzer=true;
    static unsigned long feeding;
    //vacation mode
    if (hour()==17 && minute()==0 && second()==0)
        ReefAngel.FeedingModeStart();
    if (hour() >= 8 || ReefAngel.Params.PH > 860)
        ReefAngel.Relay.Off (Box1_Port1);
        ReefAngel.Relay.Off (Box1_Port3);
    ReefAngel.Network.Cloud();
I removed the DCPump stuff.
See if this works now.
I noticed that you had both LED dimming and DCPump control using the same channels.
Previous
Return to How do I code ...
