multiple ON/Off Lights
PostPosted: Wed Jan 02, 2019 6:55 am
Happy New year Guys !
can you please help with what code I would need to put in to have my lights wich are on outlet 2 of my Exp Box open then close in the morning then then re open and close in the evening
curently I have them set to go ON at 7 am and Go off at 7 pm
what I would like is to have them go ON at 7 am the shut off at 10 AM , then Go back on at 3 pm and shut off at 7 pm
thank you
below is my code
ReefAngel.FeedingModePortsE[0] = Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port7Bit;
ReefAngel.WaterChangePortsE[0] = Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit | Port3Bit | Port4Bit;
InternalMemory.OverheatTemp_write( 840 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port7 );
ReefAngel.Relay.DelayedOn( Port3,5 );
ReefAngel.StandardLights( Port4,16,0,10,0 );
ReefAngel.StandardHeater( Port5,775,786 );
ReefAngel.StandardHeater( Port6,775,786 );
ReefAngel.StandardLights( Box1_Port1,8,0,18,0 );
ReefAngel.StandardLights( Box1_Port2,7,0,19,0 );
ReefAngel.StandardLights( Box1_Port3,10,0,15,30 );
ReefAngel.StandardLights( Box1_Port4,10,0,15,30 );
ReefAngel.PWM.SetDaylight( PWMSlope(5,0,17,0,11,60,240,11) );
ReefAngel.PWM.SetActinic( PWMSlope(5,0,17,0,0,20,240,0) );
ReefAngel.Portal( "lh2o" );
ReefAngel.DDNS( "home" ); // Your DDNS is lh2o-home.myreefangel.com
PostPosted: Wed Jan 02, 2019 11:12 am
replace this:
With this:
if (hour(now())<12)
  ReefAngel.StandardLights( Box1_Port2,7,0,10,0 );
  ReefAngel.StandardLights( Box1_Port2,15,0,19,0 );
PostPosted: Sun Jan 06, 2019 4:53 am
Thak you wprks perfect !!!
Return to How do I code ...
Users browsing this forum: Google [Bot] and 1 guest
