Alternating display values
jsclownfish
Post by jsclownfish »
I had some time today and I was thinking about how to get more info out of the space on my main display. So, I thought I might be able to switch between temperature monitors or maybe have them scroll in the same area on the screen. I remember being advised against using the delay function and that seems to make sense as the temp monitors don't update when things are in a delay. I tried two things: one was scrolling the three temp values across the screen (that didn't work so well), and the second was to switch between temp probes. I am using the Modulo function and the second clock to determine when to switch (or move in the case of scrolling). Is there a better way to do this or is this a bad idea I am not foreseeing?
Here is the demo code I am using....
// test of scrolling or alternating values onthe custom display
int timescroll;
byte a;
byte b;
void ScrollTemp(byte x, byte y)
    ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,x,y,"TANK");
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_BLACK, x+25, y, 10);
    ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,x+50,y,"SUMP");
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_BLACK, x+75, y, 10);
    ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+105,y,"ROOM");
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_BLACK, x+135, y, 10);
   //Option 1. scrolling the temperature using time across the display
          ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,1,10,"TEMP:");
          if (second()<=13)
          timescroll = (60-(3*second()))-59;
          ScrollTemp(timescroll, 20);
          else if (second()<=26)
          timescroll = ((3*second())-77);
          else if (second()<=39)
          timescroll = (60-(3*second()))+19;
          else if (second()<=52)
          timescroll = ((3*second())-155);
          ScrollTemp(1, 20);
   // Option 2: alternating the temp display using time
   a=second() % 3;
   ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,1,50,"TEMP:");
   if (a==0)
     ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,30,50,"TANK");
     ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_BLACK, 60, 50, 10);
   else if (a==1)
     ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,30,50,"SUMP");
     ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_BLACK, 60, 50, 10);
   else if (a==2)
     ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,30,50,"ROOM");
     ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_BLACK, 60, 50, 10);
  ReefAngel.Init();  //Initialize controller and start web banner timer
-Jon
Re: Alternating display values
Modulo should work fine. I don't foresee there to be any problems with using it.
