Moon Cycle
Johan65
Moon Cycle
Post by Johan65 »
I need some Help with my Mooncycle,
      MoonPWMValue=MoonPhase();
  if (hour()==22 || hour()==7)
     MoonPWMValue=PWMSlope(22,00,7,00,2,MoonPhase(),60,2);
  if (ReefAngel.Relay.Status(Port8)) MoonPWMValue=0;
ReefAngel.LCD.DrawLargeText(COLOR_GRAY, COLOR_WHITE,25,110, "MOON");
if (ReefAngel.PWM.GetActinicValue() ==0) ReefAngel.LCD.DrawLargeText(COLOR_BLUE, COLOR_WHITE,65,110,"OFF");
else if(ReefAngel.PWM.GetActinicValue() >=1 && ReefAngel.PWM.GetActinicValue() < 20) ReefAngel.LCD.DrawLargeText(COLOR_GREEN, COLOR_WHITE,65,110,"NEW");
else if(ReefAngel.PWM.GetActinicValue() >=20 && ReefAngel.PWM.GetActinicValue() < 30) ReefAngel.LCD.DrawLargeText(COLOR_YELLOW, COLOR_WHITE,65,110,"CRESENT");
else if(ReefAngel.PWM.GetActinicValue() >=30 && ReefAngel.PWM.GetActinicValue() < 40) ReefAngel.LCD.DrawLargeText(COLOR_RED, COLOR_WHITE,65,110,"HALF");
else if(ReefAngel.PWM.GetActinicValue() >=40 && ReefAngel.PWM.GetActinicValue() < 50) ReefAngel.LCD.DrawLargeText(COLOR_PURPLE, COLOR_WHITE,65,110,"GIBBOUS");
else if(ReefAngel.PWM.GetActinicValue() >=50 && ReefAngel.PWM.GetActinicValue() < 60) ReefAngel.LCD.DrawLargeText(COLOR_ORANGE, COLOR_WHITE,65,110,"FULL");
It does swich on at 22:00 but it stays at NEW,
Any input?
Johan
Re: Moon Cycle
I think it is because we are on the new moon.
Johan65
Re: Moon Cycle
Post by Johan65 »
Hmm, But I am sure that this cycle is supposed to change about every 1 1/2 hours?
Re: Moon Cycle
Johan65
Re: Moon Cycle
Post by Johan65 »
ok, I understand that it only changes little per day, but does this code work like that,
I thought that this will be 2%-60%-2% in every night(22-7), according to what I reed in the programming
but if it works like the link you gave me, very cool
Re: Moon Cycle
This means it starts at 2% grows to whatever the moon cycle is for today within 60 minutes.
Same thing but opposite way for the other end of the cycle.
The last 2 means it will output 2% whenever is not time to ramp up or down.
http://forum.reefangel.com/viewtopic.php?f=12&t=16
Johan65
Re: Moon Cycle
Post by Johan65 »
Cool, thank you very much
