Just about to start getting my reef angel setup properly and decided to do it and wipe the basic ragen config and replace it with a more advanced one.
The issue is however, I can't upload new code!
Iv uninstalled and reinstalled and rebooted and did a little googling however I am not sure what to do. I can communicate with it when using the reef angel client however when I turn that off and try and upload I get the following error.
The following feature was automatically added:
Watchdog Timer
Version Menu
Dimming Signal
Standard Menu
Date/Time Setup Menu
Binary sketch size: 33,994 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM7 -b115200 -D -Uflash:w:C:\Users\Matt\AppData\Local\Temp\build5345867188187497203.tmp\RA_Preloaded.cpp.hex:i
Copyright (c) 2000-2005 Brian Dean, link removed
Using Port : \\.\COM7
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude done. Thank you.
Any help would be really appreciated.
