Can you confirm how the jumper configuration should be?
I have two boards and they have two different jumper configs so I don't know if I am right or not
Cannot Upload - timeout communicating with programmer
Re: Cannot Upload - timeout communicating with programmer
In the RA+ board, there is a jumper block on the left side of the joystick.
All 3 jumpers have to be in place.
Well I feel like an idiot. For some reason, rst wasnt on so I must have knocked it off when I swapped the boards. With all 3 jumpers on, I can upload code again
Thanks for the help, really appreciate it. Sent you an email about 1 more thing
Cheers
matt
Cheers
matt
I just got a reef angel plus control board and it will not program. I do not see any jumpers on my board. At least where I think I am supposed to look. My old reef angel board has one jumper. Could I be missing pieces. The new board will not communicate with my computer at all. I am plugged into the relay box and I can operate the controller but not get into the board. I can also program my old board but not my new one. I have switched the coding between the two boards.
Is this an upgrade from a Standard? Did you switch the board type under Tools->Board?
