Low Water cut off
Low Water cut off
I made stupid mistake and accidently saved over a low water cut off code that Roberto help with, I was wondering if I can get help with it again.
I wanted my Return Pump on Relay 8 to shut off when the float switch signaled low water and turn back on when the sump filled up again. I have a seperate ATO thats not part of the RA system.
Sorry, really stupid mistake, I went in to the wizard and accidently hit save at the end -
Re: Low Water cut off
That's fine.
Your code should still be intact. I think we saved with the name of Seagals_1st_Code.
Go to menu File->Sketchbook->Seagals_1st_Code to open it up.
I tried that i accidently saved over the file Seagals_1st code, We you be able to please create it again for me??
Thank you
Thank you
Sure, we only added one line in your code.
So, add it to your code in between these lines, like this:
ReefAngel.Relay.Set(Port8,!ReefAngel.LowATO.IsActive());
Thanks again, you da man!
I finally got around to running the 1 float for the low water cut off - question,since i am using it as a low water cutoff does it matter which receptor i plug it into on the head unit?
I see where the ATO receptors are on the head unit; there are 2 receptors, does it matter if i plug it on the right or left side for the low water cutoff??
Thanks in advance
Thanks in advance
The low water cut off works but its not the best situation. When the return pump in the sump cuts out on low water the remaining water in the tank continues to rush down and filling the sump. The water from the DT fills the sump enough to raise the low water float and re activate the sump, this cycle repeats itself continuosly which causes other hazards and problems.
Two questions:
1. Can the low water cutoff code be made like to overheat code? as i understand it the overheat code does not reactivate the effected ports unless manually reset. Can this be done for the low water cutoff? I thought about the delayed restart but it if the sump has low on water it will just continue to cycle.
2. I would like to add ports 1 and 7 to the low water cut off is the following correct?
ReefAngel.Relay.Set(Port1,Port7,Port8,!ReefAngel.LowATO.IsActive());
Thanks in advance for you help.
Two questions:
We can cut off and leave it off, but how do you plan on manually resetting it?
Are you using custom menu?
I did some research on custom menu but I dont think I am capable of creating a custom menu, , right now I am using the wizard but I dont think there is an option for custom menu.
To simplify, a quick and dirty way to clear it would be to enter feeding mode and exit.
Would this work around work for you?
If i do this through the 'feeding' mode will effect my ability to use the feeding mode as i currently do?rimai wrote: enter feeding mode and exit.
Currently, when i select the feeding mode my skimmer and pumps stop for 15 mins. can this still occur? if so than after 15 mins when everything turns back on wouldnt it 'clear' the low water signal and turn the main pump on again??
Sorry, i am confused can you clarify?
My buddy is trying to help me out and found a 'custom menus' tutorial version 1.1 in the forum but we have some questions when we go to the 'reef angel features' folder it pulls up the RA Gen and we dont see where to add the #define CUSTOM MENU lines. I see the tab in RA Gen that says cutom menu but the instructions are a little off.
Are we in the right area?
Is their a later version than 1.1 of the manual?
Yes, the feeding mode would still work as it should, but I think the main pump would be cleared the minute you start the feeding mode and not at the end.
Does that work for you?
If so, use this instead:
if (ReefAngel.LowATO.IsActive()) ReefAngel.Relay.RelayMaskOff&=~Port8Bit;
I hear you but i would rather not trun the main pump off and on each time i toggle the feedingh mode. I have other equipment tied to it and it will be to much.
Since i am not using the ATO feature as intended can we just tie it to the ATO feature? it seems to havethe ATO Clear toggle - can that work?
If not, i have a friend trying to help with custom menu - see my previous post for questions - thanks
I don't think ATO would work for you.
You still need to add that code I posted above regardless of which method we use to clear.
For the custom menu define, don't worry about them. They get added automatically now.
This is the same simple menu with your option added to it.
Place it above setup()
And you need this inside setup()
#include <avr/pgmspace.h>
prog_char menu3_label[] PROGMEM = "Overheat Clear";
prog_char menu5_label[] PROGMEM = "Version";
prog_char menu6_label[] PROGMEM = "Clear Low Water";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label };
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.DisplayVersion();
void MenuEntry7()
ReefAngel.Relay.RelayMaskOff=0;
Ok - We copied and compiled, seems fine and will test it out - thanks
If we decide to add a high water cutoff can i use the same menu or do i need to add a new menu?
Thanks again
Thanks again
Good morning,
It kinda worked but I was unable to turn it back on unless i unplugged the controller. For some reason last night the pump trippped on low water (never got around to testing) and stopped working as planned and did not reset as planned. (unforutunetly for me my water level was off and water flowed out of the sump and on the floor, ugh)
Anyway, the 'low water cut off' is in the menu as planned but when i selected it i got a blank screen and nothing happened. I tried plugging the controller into the laptop to reset it, nothing. The only way to clear the code was to unplug the controller.
Can you help fix this?
Here is the posted code
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port2,9,0,21,0 );
ReefAngel.StandardLights( Port3,9,0,21,30 );
ReefAngel.StandardLights( Port4,11,0,20,25 );
ReefAngel.Wavemaker( Port5,960 );
ReefAngel.Relay.Set( Port6, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.PWM.SetDaylight( PWMSlope(11,0,20,25,5,42,120,5) );
ReefAngel.PWM.SetActinic( PWMSlope(9,0,21,30,15,60,60,15) );
if (ReefAngel.LowATO.IsActive()) ReefAngel.Relay.RelayMaskOff&=~Port8Bit,Port7Bit,Port1Bit;
ReefAngel.Portal( "Seagals" );
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
Oh, I think I made a mistake
I'm so sorry.
You need to replace this:
With this:
Also, the assignment of ports need to be like this:
I'm so sorry.
ReefAngel.Relay.RelayMaskOff=255;
if (ReefAngel.LowATO.IsActive()) ReefAngel.Relay.RelayMaskOff&=~(Port8Bit | Port7Bit | Port1Bit);
Works great - Thank you!
opps!, maybe not - for some reason she cutout on low water again, this tie i was up and know the float was under 6 inches of water. This time when i plugged the controller into the computer it reset and everything restarted.
Any ideas on why she is cutting out on low water when thier is plenty of water?
Are the exposed leads touching the water?
Can you try another float switch?
I replaced the float, we'll see - the existing float looked good, soldered leads out of the way and i had the leads in a tube sealed on each side with silicone and the tube was dry. I hope it was just a faulty switch. I'll keep you posted.
I am still having issues even with the replacement float. I can try another float whe it comes in but i am not sure their would be 2 bad floats in a row. It is usually sparatic and goes off at different times of the day and night. last night it went off on low water 4 times. the 2nd time i was checking the sump and their was plenty of water in the sump. i also tried changing the location of the float in the sump but it went off 2 more times after that. i finally just unplugged the pin from the controller.
Any thoughts??
Any thoughts??
Let's try this:
This code will only do the override if the float is triggered for at least 2 seconds.
Let me know if it works this way.
static unsigned long lastATOCheck=millis();
if (!ReefAngel.LowATO.IsActive()) lastATOCheck=millis();
if (ReefAngel.LowATO.IsActive() && (millis()-lastATOCheck>2000)) ReefAngel.Relay.RelayMaskOff&=~(Port8Bit | Port7Bit | Port1Bit);
I have had issues with two floats... Well one really... In my first situation the float switch was flaky. It was under several inches of water and the float apparently didn't like to actually float. I replaced that float switch and all is working fine as of now. The second... Just today I installed another float switch in the bottom of my 44 gallon Saltwater Brute for my water change/ATO. I finished installing the float switch and went to the controller and it was showing an active (closed) state. I figured I must have another flaky float switch... NOPE My ATO/WC Pump was too close to the float switch and the magnets inside the pump were activating the float switch contacts. I moved the pump further away from the float switch and all is well. So you may just want to verify you have nothing with a magnetic field near your float switches. They CAN/WILL cause a false active state.
Nick
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
THnaks, the latest code with 2 sec delay has been working
My low water cut off has been working fine since 2012 but recently has stopped working. I tried replacing the float as well as connecting the two wires to simulate contact but the RA doesn't seem to be kicking the main pump off. I haven't changed the code since it was entered in 2012 - any thoughts?
Can you unplug the cable from RA and check if you get the same behavior when you short out the pins in the head unit??
It could be something may have damaged that port. Check for water damage.
