Hello:
Wondering what the required fuses are for the ReefAngel project?
Standard Arduino fuse settings for the Duemilanove 328p?
Low Fuse 0xFF
High Fuse 0xDA
Extended Fuse 0×05
Fuses
Re: Fuses
I used the below for original bootloader:
High Fuse = 0xDA
Low Fuse = 0xFF
Extended Fuse = 0x05
Lock bit = 0x0F
Unlock bit = 0x3F
And this for optiboot 4.0:
High Fuse = 0xDE
Low Fuse = 0xFF
Lock bit = 0x2F
Unlock bit = 0x3F
High Fuse = 0xDA
Low Fuse = 0xFF
Lock bit = 0x0F
Unlock bit = 0x3F
High Fuse = 0xDE
Low Fuse = 0xFF
Lock bit = 0x2F
Unlock bit = 0x3F
