LED Effects with PWM Expansion module
Re: LED Effects with PWM Expansion module
Although possible, we don't have function that would do connect with local weather.
What kind of pattern are you thinking for your RF module?
The short pulse can shake things up quite well.
- Express Reef
Then we must get someone to make this functionrimai wrote:Although possible, we don't have function that would do connect with local weather.
Then I`ll go with the short pulse!
So how does one going to program the weather forecast? Would be nice if one can program the pwm so that you get "warm sunny days" so the led unit have a higher peak shine period... and to do the cloud effect, but how do you program so that the pattern must never be the same? And to make the thunderstorm like to only certain months like say in the months that have heavy rain fall?
Roberto, I tried uploading this code but it gives me an error saying 'hour'was not declared in this scope. Could you help me out please?rimai wrote:And here is a PDE file you can use to test it.
Can you post the code you are actually trying to upload??
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Actinic_Channels B000001
#define Daylight_Channels B000010
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
for (int a=0;a<6;a++)
PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
for (int b=0;b<6;b++)
else lightningstatus=0;
if (lightningstatus) PWMChannel=100;
else PWMChannel=0;
//delay(10);
PWMChannel=20;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if (lightningchance)
int x=0;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
else PWMChannel=0;
//delay(10);
PWMChannel=20;
cloudindex++;
int x=0;
int x=0;
cstart*=60;
cend*=60;
Not sure what you are doing, but I was able to compile just fine.
byte PWMChannel[6];
ReefAngel.Init();
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
if (lightningstatus) PWMChannel[b]=100;
else PWMChannel[b]=0;
//delay(10);
PWMChannel[b]=20;
cloudindex++;
int x=0;
int x=0;
cstart*=60;
cend*=60;
Roberto:
I am complete lost. the code you have there, where does it go in the pde file?
- sketch_oct04a.ino
- (4.81 KiB) Downloaded 474 times
Try this:
byte PWMChannel[6];
ReefAngel.Use2014Screen();
ReefAngel.WaterChangePorts = Port1Bit;
InternalMemory.OverheatTemp_write( 840 );
ReefAngel.CustomLabels[1]="SumpFan";
ReefAngel.CustomLabels[2]="Alk";
ReefAngel.CustomLabels[3]="Calcium";
ReefAngel.CustomLabels[4]="FugeLight";
ReefAngel.CustomLabels[5]="Swabbie";
ReefAngel.CustomLabels[6]="FanLight";
ReefAngel.CustomLabels[7]="FanLight2";
ReefAngel.StandardHeater( Port1,760,780 );
ReefAngel.StandardFan( Port2,810,820 );
ReefAngel.DosingPumpRepeat( Port3,0,120,60 );
ReefAngel.DosingPumpRepeat( Port4,1,120,60 );
ReefAngel.StandardLights( Port5,23,0,15,0 );
ReefAngel.DosingPumpRepeat( Port6,0,240,120 );
ReefAngel.StandardLights( Port7,12,0,23,30 );
ReefAngel.StandardLights( Port8,12,0,23,30 );
//0 = Blue
PWMChannel[0]=PWMParabola(12,0,23,30,1,90,1);
//1 = Violet
PWMChannel[1]=PWMParabola(12,30,23,10,0,90,0);
//2 = Green
PWMChannel[2]=PWMParabola(13,0,22,50,0,40,0);
//3 = White
PWMChannel[3]=PWMParabola(13,10,22,30,0,65,0);
CheckCloud();
ReefAngel.PWM.SetChannel(0,PWMChannel[0]);
ReefAngel.PWM.SetChannel(1,PWMChannel[1]);
ReefAngel.PWM.SetChannel(2,PWMChannel[2]);
ReefAngel.PWM.SetChannel(3,PWMChannel[3]);
if (hour()<10)
ReefAngel.PWM.SetDaylight( ReefCrestMode(55,10,true) );
ReefAngel.PWM.SetActinic( ReefCrestMode(60,10,false) );
if (hour()>=10 && hour()<22)
byte random_speed=45;
if (now()%5==1) random_speed=random(45,70);
ReefAngel.PWM.SetDaylight( NutrientTransportMode(random_speed,75,10,true));
ReefAngel.PWM.SetActinic( NutrientTransportMode(random_speed,85,5,false));
if (hour()>=22 && hour()<2359)
ReefAngel.PWM.SetDaylight( ReefCrestMode(70,15,true) );
ReefAngel.PWM.SetActinic( ReefCrestMode(70,10,false) );
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
//delay(10);
PWMChannel[b]=20;
cloudindex++;
int x=0;
int x=0;
cstart*=60;
cend*=60;
Thanks Roberto! It worked great. I love the new screens. Tbh, I didn't like the reef angel display. Now with the new changes, it's great. I do t have to squint no more. Love the lightning effects.
