auto-feed
Re: auto-feed
Thanks guys for taking time on this.
Curt, i don't use a wavemaker so I'm OK, how do i setup with the use of serial monitor, looks like i have to used a command here.
also i am looking at the pde code, do i have to add a value or is there going to be a user menu that can be edited, do i have to upload auto_feed.pde before vacation?..totally nob on coding
Thanks.
Thanks.
Re: auto-feed
What I would suggest is that you take the pde I created and then merge your existing pde into it. This way you have the "vacation mode" ready to go whenever you wanted. In fact, you may even decide you want it to always be enabled so you never have to worry about feeding (or rushing home to feed or whatever).acabano wrote:Thanks guys for taking time on this.
Thanks.
Right now, there is no menu option to enable this mode for you. It would have to be enabled via the wifi or serial interface and enabled manually UNLESS you set the memory values via a pde similar to the set internal memory pde.
Currently, the client suite will not enable you to modify memory locations outside of the standard ones very easily. I've asked Dave to add in an"on the fly" type of reading/writing memory locations to make this simpler. So for now, it must be done manually.
Do you have a WIFI module?
This will simplify things and make it easier to update the values from memory. Plus, it will make enabling the vacation mode very simple. If not, we will just have to program them and then re-upload the controller code.
If you don't have WIFI, then we will want to set the memory values using arduino.
Let me know the answers to this. Also, if you could post your PDE file (attach it to a post) then we can merge the vacation mode code into your pde file so it would always be there for you whenever you needed (long weekends, vacations, late night at the office, etc).
Re: auto-feed
Hi Curt, i do have a wifi attachment. below is my pde file.
// Autogenerated file by RAGen (v1.0.4.92), (08/05/2011 19:08)
// RA_080511_1908.pde
#define ATOSetup
#define MetalHalideSetup
#define DirectTempSensor
#define wifi
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
ReefAngel.FeedingModePorts = B11000000;
ReefAngel.WaterChangePorts = B11000000;
ReefAngel.OverheatShutoffPorts = B00000000;
ReefAngel.LightsOnPorts = B00001011;
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
// Specific functions
//ReefAngel.StandardLights(Port1);
ReefAngel.MHLights(Port2);
ReefAngel.StandardLights(Port4);
ReefAngel.StandardFan(Port5);
ReefAngel.StandardATO(Port6);
// LED Ramp
// Have PWM on from 1pm to 11pm, with gradual 60 minute ramp up and down starting at the given times
// From 1pm to 2pm, actinic and 2pm to 3pm daylightthe PWM will slowly ramp from 0% to 80%
// From 9pm to 10pm, daylight and 10pm to 11pm actinic the PWM will slowly ramp from 80% to 0%
ReefAngel.PWM.SetActinic(PWMSlope(13,0,23,0,0,80,60,ReefAngel.PWM.GetActinicValue()));
ReefAngel.PWM.SetDaylight(PWMSlope(14,0,22,0,0,80,60,ReefAngel.PWM.GetDaylightValue()));
#define ATOSetup
#define wifi
// LED Ramp
Re: auto-feed
Cool. This will be simple to merge together. Once I get it merged, I'll post the PDE file for you and then the commands you will need to enter to set the values in the memory (and how to change them) plus how to enable and disable the vacation mode.
Re: auto-feed
what ports do you want shutoff 10 minutes before?
what ports do you want turned on for the autofeeder?
Re: auto-feed
i want to shutoff Port 7 and 8 10 minutes before.
for autofeeder port 1.
Re: auto-feed
Ok. Attached is the PDE file for you. I have it set to turn ports 7 & 8 off at the specified interval before starting the feeding mode. I also have port1 only turn on at the given feeding mode time then run for the specified amount of time and shutoff.acabano wrote:i want to shutoff Port 7 and 8 10 minutes before.
I would upload the code to the controller first before proceeding. It doesn't matter if you do or not, just makes things easier knowing that it's all ready to go.
Now, here comes the "fun stuff". We must add the values to memory so the controller can read them and use them.
Open up a web browser and type these in the URL / location box. I'm going to use my wifi module's IP address as an example (10.0.42.40). So where you see that IP address, you must replace it with your own IP address or else the command will not work.
Here's the commands you need to use to set the Start Hour and Minutes:
// Set the start hour to 6 pm (18 hours)
http://10.0.42.40:2000/mb701,18
// Set the start minute to 0
http://10.0.42.40:2000/mb702,0
// Set the delay to be 10 minutes before the start time
http://10.0.42.40:2000/mb703,10
// Set the run time to be 10 minutes
http://10.0.42.40:2000/mb704,10
// enable auto feed mode
http://10.0.42.40:2000/mb700,1
// disable auto feed mode
http://10.0.42.40:2000/mb700,0
- autofeed.pde
- auto feed mode
- (3.42 KiB) Downloaded 477 times
Re: auto-feed
Hi Curt, Can you please add a visual indicator, that way its easy for the user to check if the auto feed function is enabled. i will upload this pde later today and try it, thanks for the help.
Re: auto-feed
Hi Curt, it works like a charm exactly what i want... again thank you for your support.
Re: auto-feed
That's great. I'm working on the visual indicator for you right now. I've got something created but haven't tested it. I was going to put a "V" to the left of the relay box to indicate it's in "vacation mode" or "A" for the "auto feed" mode. I'm thinking more of an "A" now that I think about it. I'll post once I get it tested and confirm. Also, you can change the letter to be whatever you want but I'd suggest just keeping it as 1 letter for simplicity.
Re: auto-feed
This should work for you. It shows the indicator to the left of the relay box.
- autofeed.pde
- (4.09 KiB) Downloaded 521 times
Re: auto-feed
that's pretty awesome, I was looking for something very similar to this. I'm leaving too early for work in the morning but would like to feed twice a day so this piece of code should come in handy soon enough.
On that very topic, any recommendations on "auto feeders" that actually do work ? I'm feeding NLS sinking pellets, 1mm. Now that the RA side of thing works I'm more concerned with the device dumping a whole bucket in my tank!
Re: auto-feed
I modded my auto feeder, to trigger only when power is applied. so far it works but no guarantee...
Re: auto-feed
Curt, can you verify my pde if its correct, cuz i did not see the autofeed indicator. also i use simple menu for
space, is that affecting the code?
Thanks.
Thanks.
- Golden.pde
- (5.42 KiB) Downloaded 476 times
Re: auto-feed
just found out i was using simple menu instead of custom menu...
Re: auto-feed
cool. Glad you got it figured out.acabano wrote:just found out i was using simple menu instead of custom menu...
