How Do I change the LCD Contrast on the Simple Code?
Im2Nelson4u
Post by Im2Nelson4u »
I gave up trying to install the developmental so I'm gonna stick to the Simple Code until I have more time to learn about RAGEN and it's settings.
After I reuploaded the Simple Code the LCD seems to be too bright and I dont see anywhere in the sample code that has a contrast setting.
I can't seem to find ReefAngel.LCD.SetContrast(x); or where to put it
thx
Re: How Do I change the LCD Contrast on the Simple Code?
Nowhere to change contrast.
You will have to change the libraries to get that done.
It is inside Phillips6610LCDInv.cpp file. Look for line 338:
  sendCMD(SETCON);
  sendData(0x36);
Change the number 0x36 to a lower number.
But, I'd like to point out how to get the dev libraries installed properly.
Simply install this app: http://forum.reefangel.com/viewtopic.php?f=8&t=2
You can update/convert libraries at will with just a click of a button.
Then I suggest you watching these youtube videos: http://forum.reefangel.com/viewtopic.php?f=15&t=60
