Multiple on/off times
I'm not quite ready to do this, so I don't need to get into coding it yet.
I have a de-nitrification chamber that I pump water from the sump into 4 times a day.
1am, 7am, 1pm and 7pm.
It runs for 25 min and then triggers a dosing pump I have that drips the nitragone into the chamber for 21 min.
My main question right now is can I do something like this?
Re: Multiple on/off times
Yep, set them up as dosing pumps. Let me see if the wizard can do that for you...
Wizard doesn't like the 25 minutes. Can one of the programming geniuses chime in?
--C
--C
The dosing pump is setup for starting every x minutes for x seconds.
I didn't try it, but I didn't think it would work with a 4 hr time span for 20 to 25 min.
I'm sure there is a way to do it, but like I said it doesn't need to be nailed down right now.
Great. When I get to that step of setting everything up I will re-visit this topic.
Ok. I'm ready to get this done.
I want to control my NatuReef de-nitrification chamber with the Reef Angel.
Port 5 needs to come on for 20 min.
When that is done Port 8 needs to come on for 20min.
I need to do this 4 times a day at 1am, 7am 1pm and 7pm (with the ability to add more cycles in the future)
While all this is happening (or at least the first 20min when the pump in the sump is exchanging water) I want to disable the Water Level Expansion (Port6) from coming on and adding water to the sump.
Try this:
ReefAngel.Relay.Set(Port5,now()%21600<1200) // Runs for 1200s every 21600 seconds
ReefAngel.Relay.Set(Port8,(now()+1200)%21600<1200) // Runs for 1200s every 21600 seconds with 1200s offset
if (ReefAngel.Relay.Status(Port5))
ReefAngel.Relay.Off(Port6);
ReefAngel.WaterLevelATO(Port6,60,75,79);
Roberto;
I'm getting the following error when I added the code above and changed the parameters for the Water Lever.
Here is my full code;
It looks like it is referring to something in the custom wave section, but I didn't touch that, I just added your code right before the Custom Wave code.Steves_Custom_Wave_Sketch.cpp: In function 'void loop()':
Steves_Custom_Wave_Sketch:72: error: expected `;' before 'ReefAngel'
Steves_Custom_Wave_Sketch:75: error: 'else' without a previous 'if'
[quote]
#include <[color=#CC6600]Wire[/color].h>
#include <[color=#CC6600]OneWire[/color].h>
#include <[color=#006699]LED[/color].h>
#include <[color=#006699]Relay[/color].h>
#include <[color=#006699]Timer[/color].h>
#include <[color=#006699]Salinity[/color].h>
#include <[color=#006699]RF[/color].h>
#include <[color=#006699]IO[/color].h>
#include <[color=#006699]ORP[/color].h>
#include <[color=#006699]AI[/color].h>
#include <[color=#006699]PH[/color].h>
#include <[color=#006699]WaterLevel[/color].h>
#include <[color=#CC6600]ReefAngel[/color].h>
[color=#7E7E7E]////// Place global variable code below here[/color]
[color=#7E7E7E]////// Place global variable code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]setup[/b][/color]()
[color=#7E7E7E]// This must be the first line[/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]Init[/color](); [color=#7E7E7E]//Initialize controller[/color]
[color=#7E7E7E]// Ports toggled in Feeding Mode[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]FeedingModePorts[/color] = 0;
[color=#7E7E7E]// Ports toggled in Water Change Mode[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]WaterChangePorts[/color] = [color=#006699]Port4Bit[/color];
[color=#7E7E7E]// Ports toggled when Lights On / Off menu entry selected[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LightsOnPorts[/color] = [color=#006699]Port1Bit[/color] | [color=#006699]Port2Bit[/color];
[color=#7E7E7E]// Ports turned off when Overheat temperature exceeded[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]OverheatShutoffPorts[/color] = [color=#006699]Port1Bit[/color] | [color=#006699]Port2Bit[/color];
[color=#7E7E7E]// Use T2 probe as temperature and overheat functions[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]TempProbe[/color] = [color=#006699]T2_PROBE[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]OverheatProbe[/color] = [color=#006699]T2_PROBE[/color];
[color=#7E7E7E]// Set the Overheat temperature setting[/color]
[color=#CC6600]InternalMemory[/color].[color=#CC6600]OverheatTemp_write[/color]( 825 );
[color=#7E7E7E]//Set Standard Menu[/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]AddStandardMenu[/color]();
[color=#7E7E7E]// Ports that are always on[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port4[/color] );
[color=#7E7E7E]////// Place additional initialization code below here[/color]
[color=#7E7E7E]////// Place additional initialization code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]loop[/b][/color]()
[color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Port1[/color],12,0,22,0 );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Port2[/color],13,0,21,0 );
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Set[/color]( [color=#006699]Port3[/color], ![color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Status[/color]( [color=#006699]Port1[/color] ) );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Port7[/color],13,0,21,0 );
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Set[/color]([color=#006699]Port5[/color],[color=#CC6600]now[/color]()%21600<1200) [color=#7E7E7E]// Runs for 1200s every 21600 seconds[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Set[/color]([color=#006699]Port8[/color],([color=#CC6600]now[/color]()+1200)%21600<1200) [color=#7E7E7E]// Runs for 1200s every 21600 seconds with 1200s offset[/color]
[color=#CC6600]if[/color] ([color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Status[/color]([color=#006699]Port5[/color]))
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Off[/color]([color=#006699]Port6[/color]);
[color=#CC6600]else[/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]WaterLevelATO[/color]([color=#006699]Port6[/color],720,21,23);
[color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetActinic[/color](MyCustomWave(50));
[color=#CC6600]if[/color]( [color=#CC6600]ReefAngel[/color].[color=#006699]DisplayedMenu[/color]==[color=#006699]FEEDING_MODE[/color] ) [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetActinic[/color](0);
[color=#CC6600]if[/color]( [color=#CC6600]ReefAngel[/color].[color=#006699]DisplayedMenu[/color]==[color=#006699]WATERCHANGE_MODE[/color] ) [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetActinic[/color](0);
[color=#CC6600]if[/color] (hour()<12 || hour()>=22) [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetActinic[/color](30);
[color=#7E7E7E]////// Place your custom code below here[/color]
[color=#7E7E7E]////// Place your custom code above here[/color]
[color=#7E7E7E]// This should always be the last line[/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]Portal[/color]( [color=#006699]"Sacohen"[/color],[color=#006699]"Seth0310"[/color] );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]ShowInterface[/color]();
[color=#CC6600]void[/color] DrawCustomMain()
[color=#CC6600]int[/color] x,y;
[color=#CC6600]char[/color] text[10];
[color=#7E7E7E]// Parameters[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawMonitor[/color]( 15, 20, [color=#CC6600]ReefAngel[/color].[color=#006699]Params[/color],
[color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]GetDaylightValue[/color](), [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]GetActinicValue[/color]() );
#else [color=#7E7E7E]// defined DisplayLEDPWM && ! defined RemoveAllLights[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawMonitor[/color]( 15, 20, [color=#CC6600]ReefAngel[/color].[color=#006699]Params[/color] );
#endif [color=#7E7E7E]// defined DisplayLEDPWM && ! defined RemoveAllLights[/color]
[color=#CC6600]pingSerial[/color]();
[color=#7E7E7E]// Water Level[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color]( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, [color=#006699]"WL:"[/color] );
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color]( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, [color=#CC6600]ReefAngel[/color].[color=#006699]WaterLevel[/color].[color=#CC6600]GetLevel[/color]() );
[color=#7E7E7E]// Main Relay Box[/color]
[color=#CC6600]byte[/color] TempRelay = [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayData[/color];
TempRelay &= [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayMaskOff[/color];
TempRelay |= [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayMaskOn[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawOutletBox[/color]( 12, 92, TempRelay );
[color=#7E7E7E]// Date and Time[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawDate[/color]( 6, 122 );
[color=#CC6600]void[/color] DrawCustomGraph()
[color=#CC6600]byte[/color] MyCustomWave([color=#CC6600]byte[/color] maxspeed)
[color=#CC6600]static[/color] [color=#CC6600]byte[/color] randomspeed=0;
[color=#CC6600]if[/color] ([color=#CC6600]now[/color]()%11<5)
[color=#CC6600]return[/color] randomspeed;
[color=#CC6600]else[/color] [color=#CC6600]if[/color] ([color=#CC6600]now[/color]()%11>=5 && [color=#CC6600]now[/color]()%11<10)
[color=#CC6600]return[/color] maxspeed;
randomspeed=[color=#CC6600]random[/color](35,maxspeed);
[color=#CC6600]return[/color] 0;
[/quote]
Oh, sorry...
I missed two ; at the end of the first 2 lines before the comments.
It looks like just one right here after <1200) and before the comment
ReefAngel.Relay.Set(Port5,now()%21600<1200); // Runs for 1200s every 21600 seconds
If I put a ; after the (Port5) I get an error.
If I put 2 ; after <1200) and before the comment it compiles fine also.
Which should it be?
Which should it be?
Something else is wrong. Its not that line. Check the few lines above.
Is it this line...
ReefAngel.Relay.Set( Port3, !ReefAngel.Relay.Status( Port1 ) );
That looks wrong to me, but I'm not sure how it is supposed to be.
I ran thru the wizard again and that's how it came out again.
From everything else I see it looks like it should be like this...
ReefAngel.Relay.Set( Port3, );
ReefAngel.Relay.Status( Port1 );
But Port3 is supposed to be opposite Port1.
It's these two lines...
This is how it should look:
They were both missing the ;
ReefAngel.Relay.Set(Port8,(now()+1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
Thanks somehow when I was checking and changing things I deleted the 2nd line...
Something else strange is going on now. My water level has stopped working.
It started showing 200% and then went to 0%.
I tried running the Water Calibration again and when it runs the 100% portion it shows 0%.
Now it is switching between 200% and 0% and I here Port6 which controls the ATO Pump switching on and off.
I unplugged the ATO pump when it went to 200% the first time because it started putting water in the sump.
I don't think it is this code, because I haven't uploaded it yet.
Take a look at the relay activity for Port 6...
Roberto or Lee can you explain what the code is doing?
Obviously the comments say Runs for 1200s every 21600 seconds and Runs for 1200s every 21600 seconds with 1200s offset and that translates to runs for 20 min every 6 hours and runs form 20 min every 6 hours with a 20 min offset.
It isn't working right and I want to not only try to figure it out, but understand what is written so I can write more in the future.
At 11:40 pm Port 8 came on and went of at 12:00 am and then Port5 came on at 12:00am and went off at 12:20am.
Then at Port At 5:36 Port8 came on and went of at 5:56 am and Port5 came on at 5:56 am and off at 6:16am.
First of all Port5 should come on before Port8.
Second it needs to happen at 1am not 12am and 7am not 6am.
I know the portal is not up to the minute, but the Port on's and off's look like they ramp up over a 5 min period.
Which point should I trust?
Right now I'm going with the beginning of the ramp up as the on and the beginning of the ramp down as the off.
I don't actually have the pumps for this activity plugged in yet, they are still running on the old timers because I want to make sure everything is working correctly before I switch them over.
I think the answer is that the on time is somewhere between the start of the ramp and the top. It sees that there is no activity during one refresh, and activity during the next, so it puts a ramp in between.
Here's what the code does.
Port5 is the port we are switching. The second part is a boolean (true/false) value. 0 would mean off (false), 1 would mean on (true). now() is the number of seconds since 1/1/1970, so it's just a timer that is always increasing. % is the modulus operator. It returns the remainder from division, like 6/4 = 1 remainder 2. So, the second part of the statement says if the remainder of now() divided by 21600 is less than 1200 (the statement is true) then turn the pump on, otherwise turn the pump off.
So, every 6 hours (21600 seconds), we can divide the value of now() (which is universal and increases every second) and get a remainder that is less than 1200 (20 minutes). After 20 minutes, the remainder is larger than that and we know to turn the pump off.
It's a little simpler like this:
So, we have two ways to code the same thing.
The second line works the same, although the +1200 confuses me as to why it works to offset. I can't wrap my head around it right now.
The "if" statement says if Port5 is on, then turn port6 off, else let the ATO control port6.
Hope this helps,
if (now()%21600 < 1200) { ReefAngel.Relay.Set(Port5 , 1 ); } // Pump on
else { ReefAngel.Relay.Set(Port5 , 0 ); } // Pump off
Hope this helps,
The first line (port5) turns that port on every 6 hours at 12 am, 6 am, 12 noon and 6 pm. To shift it an hour ahead you would have to change the expression to (now()- 3600).
In the 2nd line controlling port8, the expression (+ 1200 ) should be (- 1200). Otherwise the logic is fine.
Sent from my Samsung Galaxy tablet - expect terse answers and typoes
Hmmm, since you are adding 1200 and looking at the remainder only, wouldn't the value be the same?
Say now()=1, then now()+1200=1201
Then 1%1200 = 1
and 1201%1200 = 1
Am I missing something here?
Then 1%1200 = 1
and 1201%1200 = 1
That's true but you are dividing by 21600 not 1200. If you added 21600 to the now() expression it would have no effect as you stated above. But when you add a smaller value (1200 in this case) to now() you shift the "on" window 1200 seconds earlier in time. When you subtract a value you shift the window later.
Picture now() returning 21599. Now() % 21600 would result in the port being off at this instance. If you desired that the port be on at this instance, you would have to add an offset of 1second which would slide that "on" window earlier by one second.
edited
edited
I'm not sure, you got me confused a little bit, but the offset is to trigger a separate dosing pump to deliver the Nitragone liquid to the chamber for 20 min after the first pump does a water exchange for 20 min.
That's what I was missing!billw wrote:That's true but you are dividing by 21600.
Forgive me, it's early.
So something like this?
ReefAngel.Relay.Set(Port5,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
ReefAngel.Relay.Set(Port8,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
That should do it. Port5 on at 1AM,7AM,1PM,and 7PM and port 8 20 minutes later.
I'm not sure where the 3600 goes. I tried the code below, but the compiler failed and I really didn't understand the error message yet.billw wrote:The first line (port5) turns that port on every 6 hours at 12 am, 6 am, 12 noon and 6 pm. To shift it an hour ahead you would have to change the expression to (now()- 3600).
This is the error message.
Steves_Custom_Wave_Sketch:72: error: void value not ignored as it ought to be
Steves_Custom_Wave_Sketch:72: error: expected `;' before ')' token
Like this...
ReefAngel.Relay.Set(Port5,(now()- 3600)%21600<1200); // Runs for 1200s every 21600 seconds
ReefAngel.Relay.Set(Port8,(now()- 3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
ReefAngel.WaterLevelATO(Port6,720,22,24);
What he had passed the compiling, so I'll upload it and see what it does before I actually move the plugs over to the RA.
Thanks for the help everyone.
It makes a little more sense.
Slow but surely I'll get a hang of this.
Sorry about that. You need an extra open paren in the port8 expression right before (now())
Set(Port8,((now()- 3600)
ReefAngel.Relay.Set(Port8,((now()- 3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
Well the 1pm cycle just went by and it looks like everything worked ok.
Port5 came on at 1pm and ran until 1:20pm and then Port8 came on at 1:20pm and ran until 1:40pm and all that time Potr6 (the ATO port) did not trigger and I know it was low enough to trigger when the De-nitrate water exchange started happening.
It looks like it's set up correctly now. I may watch 1 more cycle (at 7pm) to see if it is still good.
Thanks again everyone.
The only issue I have with set up so far is that when Port5 stops Port6 for the ATO automatically kicks in because the De-nitrification chamber has not quite returned all of the water back to the sump yet.
Is there a way we can add a 2 min delay after the water exchange happens on Port5 before Port6 will do anything?
I'm guessing it would be something like..
But I don't know the correct syntax of ; and ) yet.
ReefAngel.WaterLevelATO(Port6,720,29,31);
if (ReefAngel.Relay.Status(Port5) + 120)
ReefAngel.Relay.Status returns a 0 for off and a 1 for on (boolean, true/false) so you can't just add 120 there.
Try this:
This goes near the top right above ////// Place global variable code above here
Remove this:
And try this instead:
Try this:
unsigned long ATOUpdate=0;
if (ReefAngel.Relay.Status(Port5) && ATOUpdate==0) // Check to see if port 5 is on and update time is empty
{ ATOUpdate = now(); // If so, set the update time to now
ReefAngel.Relay.Off (Port6); } // and turn off the ATO pump
if (now() - ATOUpdate >= 120 && ATOUpdate != 0) // If it's been 120 sec, and the update time is NOT empty
{ ATOUpdate = 0; // Empty out the update time
ReefAngel.WaterLevelATO(Port6,720,29.31); } // and turn the ATO sensor back on
Thanks Colin, I'll try it when I get home tonight, but is the
going to interfere with the 2nd part of the De-nitrification process (the dosing of the Nitragone liquid for 20 min)
In this code...
In this code...
