Is there a way to exit the water change mode programmatically? i.e. If I want to use the IO module to trigger the water change mode using ReefAngel.WaterChangeModeStart() how can I get out of feeding mode? Or simulate a button press...
How does the RA react to the ButtonPress++? I have this at the end of my water change code and it does return to the main screen, but it almost seems like a reboot. The screen goes blank while the red light is blinking quickly. Then the Reef Angel logo comes up and the RA returns to normal.
Is this the expected result of simulating the button push? Thx
I figured this out. I was leaving the RA connected to my PC, which was causing random reboots. I disconnected the USB and the button press code worked as expected. Thx
