Dosing Pump not running on Schedule
Re: Dosing Pump not running on Schedule
byte portalSeconds[numPumps] = { 1, 3, 5 };
if (now()%SECS_PER_DAY==SECS_PER_DAY-1) {
// Backup timers to portal variable
ReefAngel.CustomVar[portalSeconds[0]] = pumpTimer[0]/60;
ReefAngel.CustomVar[portalSeconds[1]] = pumpTimer[1]/60;
ReefAngel.CustomVar[portalSeconds[2]] = pumpTimer[2]/60;
pumpTimer[0]=0; // Clear timer for Port3
pumpTimer[1]=0; // Clear timer for Port4
Something isn't right. Fields 0 and 2 reset themselves at 2pm this afternoon. Fields 1 and 3 are both displaying 0.
1 and 3 will not show data till after midnight. 12:05 the latest
Right. I had some data in fields 0 and 1 last night when it should have pulled but still had zeros today. I will wait to see what happens tonight after midnight and update you tomorrow.
Did you copy my whole code i posted above? I commented out the line that updates the seconds fields so it should only get updated at midnight. If you tried to merge its an easy miss...
Make sure the line in the main loop that updates the seconds on the portal is commented...
I will check the code tonight. Fields 1 and 3 didn't pull last night.
I loaded the code exactly as it was written in your post on 6/18 at 6:13pm. The only change I made was that I kept the ATO reset function as "maskON". So something is preventing the data to pull correctly at 11:59pm.kirkwood wrote:I will check the code tonight. Fields 1 and 3 didn't pull last night.
Can you post the whole code again so I can review it as it is. Sorry for the trouble, but I don't see how it's not gettign set...
will do. i will post full code this evening
Here is my full code
ReefAngel.FeedingModePorts = Port5Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port6Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.MHLights( Port1,16,0,23,0,5 );
ReefAngel.MHLights( Port2,17,0,21,30,10 );
ReefAngel.DosingPumpRepeat( Port3,0,120,292 );
ReefAngel.DosingPumpRepeat( Port4,60,120,340 );
ReefAngel.StandardHeater( Port6,775,805 );
ReefAngel.StandardATO( Port7,900 );
//Start Feeding Mode at 17:00 and 21:00
if ( (now()%86400==61200) || (now()%86400==75600) ) {
ReefAngel.FeedingModeStart();
const byte numPumps=3;
byte pump[numPumps] = { Port3, Port4, Port7 };
byte portalMinutes[numPumps] = { 0, 2, 4 };
static time_t pumpTimer[numPumps];
static boolean pumpStatus[numPumps];
static boolean atoDisabled;
for (int i=0;i< numPumps;i++) {
if (ReefAngel.Relay.Status(pump)) {
if (!pumpStatus) {
pumpTimer=now()-pumpTimer; // Pump was off, timer is now a time
pumpStatus=true;
if (pumpStatus) {
pumpTimer=now()-pumpTimer; // Pump was on, timer is now a timer
pumpStatus=false;
// Normalize and assign to CustomVar for reporting on the portal
ReefAngel.CustomVar[portalMinutes]=pumpTimer[i]/60; // Number of Minutes
// ReefAngel.CustomVar[portalSeconds[i]]=pumpTimer[i]%60; // Number of Seconds
if (bitRead(ReefAngel.Relay.RelayMaskOn, 6)==1) { // ATO relay was forced on
atoDisabled=true; // don't want to change the variable names yet.. but you may want to to make it clearer..
if (atoDisabled && (bitRead(ReefAngel.Relay.RelayMaskOn, 6)==0)) { // ATO override has been cleared
pumpTimer[2]=0; // Clear timer for ATOPort
atoDisabled=false;
ReefAngel.Portal( "kirkwood" );
if (!pumpStatus) {
pumpStatus=true;
if (pumpStatus) {
pumpStatus=false;
atoDisabled=false;
Nevermind I know what the problem was. We need to make sure that the clearing and backing up only happens once. Right now it's happening a few times for the second before midnight which is not what we want because it's lost after the first run. Anyway, here's a fix.
static boolean clearTimer;
if (now()%SECS_PER_DAY!=SECS_PER_DAY-1) clearTimer=true;
if ((now()%SECS_PER_DAY==SECS_PER_DAY-1) && clearTimer==true) {
clearTimer=false;
Got an error on this line of code:
if (now()%SECS_PER_DAY==SECS_PER_DAY-1 && clearTimer=true) {
1value required as left operand of assignment
Sorry put () around the first test
if ( (now()%SECS_PER_DAY==SECS_PER_DAY-1) && clearTimer=true) {
It still gives the same error.lnevo wrote:Sorry put () around the first test
It need to be like this:
if ( (now()%SECS_PER_DAY==SECS_PER_DAY-1) && clearTimer==true) {
I loaded the new code this afternoon so I will report back tomorrow
Success!kirkwood wrote:I loaded the new code this afternoon so I will report back tomorrow
Everything has been working well but this morning I noticed something that didn't make sense. Custom Fields 4 and 5 are my ATO minutes and ATO seconds, respectively. This morning field 4 was 62 and field 5 was 62. That makes me wonder if field 5 is programmed to pull the field 4 value at 11:59pm each night like my ALK and CAL. It doesn't really matter to me either way because the ATO seconds value is of little consequence.
I had a final idea on tracking dosing values - right now we are tracking in field 0&2 the dosing minutes for the day that resets at the end of each day, field 1&3 that updates each night at 11:59pm with the value of fields 0&2. And then maybe we do fields that will keep a running total of minutes that carrys over from day to day so that I can track when my dosing reservoir is close to empty. Basically after field 1 updates with the total dose for the day, another field would add that number to its existing total and that would continue each day until I reset it in the same way I would reset the ATO via the masking function.
So basically in the end I would do Fields 0,3 for daily running tally of minutes, fields 1,4 that pulls field 0,3 value at 11:59pm each day, fields 2,5 that adds the value of field 1,4 to the existing value of field 2,5 each day, and field 6 would be my ATO minutes. Fields 2,5,6 would all need to be able to be reset via the masking functionality we've been using for the ATO.
I don't need this right now, as my code is working nicely right now and i'm about to put it to the test by heading out of town for a bit, so I don't want to load any new code that I will need to tinker with...
Yes, ato time is being backed up to to field 5 same as the alk and cal.
As far as keeping a running total, the problem is the field can't hold a number greater than 255.
We can do something else, but i'm working on something in my head that may help
I'm listening.....lnevo wrote:but i'm working on something in my head that may help
So...my RA knows when I refill my top off...and it knows how long it will last...it knows when I do water changes...It knows when my skimmate container is full... it knows when I last fed my fish (since setting up the AutoFeeder, I only feed frozen/manually once or twice a week) and of course as you said how much I'm dosing and how long my additives should last. (since I'm dosing by volume)kirkwood wrote:I'm listening.....lnevo wrote:but i'm working on something in my head that may help
I think the only major tasks aside from cleaning glass, cleaning sponges, and changing filter socks is when I change my GFO and GAC.
Anyway what I was thinking of doing was coming up with some way to setup reminders for all my maintenance tasks. The main problem is that I don't want to store unsigned long numbers in memory and we need to be able to remember when things were done across resets..
I think I could do something similar to my acclimation routine where we keep a running countdown or count-up...till the task is due again or when last done.
In the case where we can calculate like additive refill or top off refill we can sub in our calculated numbers, We could easily trigger a reset function when we refill our dosing containers.. Or media reactor changing...using a byte we could then store countdowns almost 8 months long (RO/DI filter changes?)
We could then store the tasks in a byte using bit flags to indicate what needs to be done...or us WiFiAlert to send a reminder.
Hard part is making it easy to use....
Lee, looking for some assistance with the code you've posted or what I might be missing.
Here is my current code:
Ignore all the silly stuff I am playing with still, I edited them out to get this working.
When I go to the variables, I don't even see a chart. Any ideas?
http://forum.reefangel.com/status/chart ... &filter=c0
http://forum.reefangel.com/status/chart ... &filter=c1
http://forum.reefangel.com/status/chart ... &filter=c2
http://forum.reefangel.com/status/chart ... &filter=c3
http://forum.reefangel.com/status/chart ... &filter=c4
http://forum.reefangel.com/status/chart ... &filter=c5
/*Port Designations
Port1 - Dosing Pump 1 (every 60min for 10s)
Port2 - Dosing Pump 2 (every 60min for 10s w/5 min offset)
Port3 - Left Radion
Port4 - Right Radion
Port5 - Heater
Port6 - ATO
Port7 - Skimmer
Port8 - Return
Box1_Port1 - Vortech
Box1_Port2 - Cabinet LED
// Define Relay Ports by Name
#define DPump1 1
#define DPump2 2
#define LeftRadion 3
#define RightRadion 4
#define Heater 5
#define ATOPort 6
#define Skimmer 7
#define Return 8
#define Vortech Box1_Port1
#define CabinetLED Box1_Port2
#define Unused Box1_Port3
#define Unused Box1_Port4
#define Unused Box1_Port5
#define Unused Box1_Port6
#define Unused Box1_Port7
#define Unused Box1_Port8
byte buzzer=0;
byte overheatflag=0;
byte atoflag=0;
time_t running1, running2; //Records run time for dosing pumps (i.e. running1 = time for DP1)
ReefAngel.FeedingModePorts = Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPortsE[0] = Port2Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit;
ReefAngel.Relay.On( LeftRadion );
ReefAngel.Relay.On( RightRadion );
ReefAngel.Relay.On( Return );
ReefAngel.Relay.On( Vortech );
// ATO locked on for now
ReefAngel.Relay.On( ATOPort );
ReefAngel.DosingPumpRepeat1( DPump1 ); //every 60min for 10s
// Other format ReefAngel.DosingPumpRepeat( Port3,10,360,10 );
ReefAngel.DosingPumpRepeat2( DPump2 ); //every 60min for 10s w/5 min offset
ReefAngel.StandardHeater( Heater );
// ReefAngel.StandardATO( ATOPort );
ReefAngel.Relay.DelayedOn( Skimmer );
ReefAngel.Relay.Set( CabinetLED, !ReefAngel.Relay.Status( Vortech ) );
ReefAngel.RF.UseMemory = true;
ReefAngel.RF.ChannelWhiteParabola();
ReefAngel.RF.ChannelRoyalBlueParabola();
ReefAngel.RF.ChannelRedParabola();
ReefAngel.RF.ChannelGreenParabola();
ReefAngel.RF.ChannelBlueParabola();
ReefAngel.RF.ChannelIntensityParabola();
overheatflag = InternalMemory.read( Overheat_Exceed_Flag );
atoflag = InternalMemory.read( ATO_Exceed_Flag );
buzzer = overheatflag + atoflag;
if ( buzzer >= 1 ) buzzer = 100;
//*******************Dosing and ATO Pump Logging************************
byte pump[numPumps] = { DPump1, DPump2, ATOPort };
pumpTimer[0]=0; // Clear timer for DPump1
pumpTimer[1]=0; // Clear timer for DPump2
clearTimer=false;
if (ReefAngel.Relay.Status(pump[i])) {
if (!pumpStatus[i]) {
pumpTimer[i]=now()-pumpTimer[i]; // Pump was off, timer is now a time
pumpStatus[i]=true;
if (pumpStatus[i]) {
pumpTimer[i]=now()-pumpTimer[i]; // Pump was on, timer is now a timer
pumpStatus[i]=false;
ReefAngel.CustomVar[portalMinutes[i]]=pumpTimer[i]/60; // Number of Minutes
if (bitRead(ReefAngel.Relay.RelayMaskOff, 6)==0) { // ATO relay is manually disabled
atoDisabled=true;
if (atoDisabled && (bitRead(ReefAngel.Relay.RelayMaskOff, 6)==1)) { // ATO override has been cleared
pumpTimer[2]=0; // Clear timer for Port7
atoDisabled=false;
ReefAngel.Portal( "alexwbush" );
// Add this for more than 1 screen
#define NumScreens 2
int ScreenID=0;
switch (ScreenID)
case 0:
//Draw screen 0
byte x = 6;
byte y = 2;
byte t;
byte radionchannel=0;
byte radiontext=0;
byte radioncolor=0;
char text[7];
/* Drawing this:
01/01/12 00:00:00 AM
Disp 79.9 pH 8.00
Sump 79.9 Sal 0.60
Room 77.7 WtrLvl Ok
1 2 3 4 5 6 7 8
1 2 3 4 5 6 7 8
Moon Waning Crescent
Intensity 88%
Sunrise 06:15
Sunset 18:12
/* Colors used in this script:
DefaultFGColor - For basic font and line
DefaultBGColor - For background color
PHColor - For values that may change
OutletOnBGColor - For okay water level
OutletOffBGColor - For low water level
To change colors, modify these values in ReefAngel_CustomColors.h file
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.Clear(DefaultFGColor, 1, 11, 128, 11);
//ReefAngel.LCD.DrawText(fcolor,bcolor,x,y,"text");
//Line 1 - Display Temp & pH
x = 8;
y = 15;
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Disp");
x += 30;
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], PHColor, x, y, 10);
x = 70;
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"pH");
x += 30;
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, PHColor, x, y, 100);
//Line 2 - Sump & Salinity
x = 8;
y += 10;
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Sump");
x += 30;
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], PHColor, x, y, 10);
x = 70;
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Sal");
x += 30;
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Salinity, PHColor, x, y, 10);
//Line 3 - Room
x = 8;
y += 10;
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Room");
x += 30;
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], PHColor, x, y, 10);
x = 70;
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"WL");
x += 30;
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.WaterLevel.GetLevel(), PHColor, x, y, 1);
//Lines 4 and 5 - Relays
x = 12;
y += 12;
// draw main relay
y +=12;
// Relay Expansion
ReefAngel.LCD.DrawOutletBox(x, y, TempRelay );
break;
case 1:
//Draw quick screen
byte x = 6;
byte y = 2;
byte t;
byte radiontext=0;
byte radioncolor=0;
char text[7];
/* Drawing this:
79.9 79.7 77.7 34.5
Sump 79.9 Sal 34.5
Room 77.7 WtrLvl 77
1 2 3 4 5 6 7 8
1 2 3 4 5 6 7 8
Intensity 88%
Sunrise 06:15
Sunset 18:12
x = 8;
y = 15;
x += 30;
x += 30;
x += 40;
//Line 3
x = 8;
y += 10;
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Work in Progress");
x = 8;
y += 10;
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Push Joystick Left");
x = 8;
y += 10;
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"to return to main display");
break;
if (ReefAngel.Joystick.IsLeft())
ScreenID--;
if (ReefAngel.Joystick.IsRight())
ScreenID++;
// PWM Parameters
/*#if defined DisplayLEDPWM && ! defined RemoveAllLights
ReefAngel.LCD.DrawMonitor( 15, 10, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 10, ReefAngel.Params );
What errors are you getting and what do you mean by a chart?
I am not getting any errors. The problem is the chart doesn't even show. So when you click on any of those links... no graph or anything.
The links in the post were specific to the op. are you just clicking them or did you modify the url?
I modified them for my portal ID "alexwbush"lnevo wrote:The links in the post were specific to the op. are you just clicking them or did you modify the url?
