Help with my definitions and modes
Smotz
Post by Smotz »
Hey all,
Can someone advise why my modes (feeding, water change, etc) aren't working with my definitions?
#define Heater Port1
#define Topoff Port2
#define Reactor Port3
#define Skimmer Port4
#define Return Port5
#define Wave Port6
#define UVlight Port7
#define Fugelight Port8
#define HeaterBit  0
#define TopoffBit  1
#define ReactorBit  2
#define SkimmerBit  3
#define ReturnBit  4
#define WaveBit  5
#define  UVlightBit  6
#define FugelightBit  7
   ReefAngel.FeedingModePorts = TopoffBit | ReactorBit | SkimmerBit | ReturnBit | UVlightBit;
   ReefAngel.WaterChangePorts = HeaterBit | TopoffBit | ReactorBit | SkimmerBit | ReturnBit | WaveBit | UVlightBit;
    ReefAngel.LightsOnPorts = FugelightBit;
   ReefAngel.OverheatShutoffPorts = HeaterBit | TopoffBit | ReactorBit | SkimmerBit | ReturnBit | WaveBit | UVlightBit;
Re: Help with my definitions and modes
Your "BITS" need to be left shifted in order to work. Here's what the code looks like in the Globals.h file.
// Port bits
#define Port8Bit   1<<7
#define Port7Bit   1<<6
#define Port6Bit   1<<5
#define Port5Bit   1<<4
#define Port4Bit   1<<3
#define Port3Bit   1<<2
#define Port2Bit   1<<1
#define Port1Bit   1<<0
So your code needs to be improved to be this:
#define FugelightBit   1<<7
#define UVlightBit   1<<6
#define WaveBit   1<<5
#define ReturnBit   1<<4
#define SkimmerBit   1<<3
#define ReactorBit   1<<2
#define TopoffBit   1<<1
#define HeaterBit   1<<0
Using this will make it work properly. You were almost there just missing a small detail.
Smotz
Post by Smotz »
binder wrote:Your "BITS" need to be left shifted in order to work. Here's what the code looks like in the Globals.h file.
// Port bits
Not sure I understand completely. Are you saying that I should just have 1 space after the declaration?
No, the values aren't just 0-7. I think that worked for me for a while because I was using it with the bitRead/bitWrite function which wanted the 0-7 as the argument.
The real values should be 1,2,4,8,16,32,64,128
so 1<<0, 1<<1, 1<<2, 1<<3, 1<<4, 1<<5, 1<<6, 1<<7 represents the bits properly.
Smotz
Post by Smotz »
I see. So I would literally type "1<<0" (without the quotes)
Yep
Smotz
Post by Smotz »
You guys are always the best
Smotz wrote:I see. So I would literally type "1<<0" (without the quotes)
or you could just copy and paste the code i provided for you. ;)
Smotz
Post by Smotz »
Thank you - sometimes I am a bit dense :cry:
Smotz
Post by Smotz »
How would I represent the 2nd relay box?
2<<1
2<<2
2<<3
and so on?
Its the same as the first relay box. You'd be addressing a different variable but the bit positions are the same. 0-7 = ports 1-8
Smotz
Post by Smotz »
lnevo wrote:Its the same as the first relay box. You'd be addressing a different variable but the bit positions are the same. 0-7 = ports 1-8
can you be more specific?
#define Wave Port6
#define Fugelight Box1_Port8
#define FugelightBit   2<<7
Just use Box1_Port1 through Box1_Port8
Smotz
Post by Smotz »
rimai wrote:Just use Box1_Port1 through Box1_Port8
can you provide the code to define my FugeLightBit?
1<<7
Smotz
Post by Smotz »
rimai wrote:1<<7
Thank you
Yes, the PortBit variables represent which bit in the RelayData byte and RelayMask byte. Since the bit positions are the same for relay box 1 and relay box 2 etc, the PortXBit is the same for all relay boxes.
ie Port1Bit is 1<<0 meaning we shift the bit 0 positions to represent the first bit.
The position is the same whether we are talking about RelayData or RelayDataE[0]
Smotz
Post by Smotz »
i think i got it. thank you all.
Smotz
Post by Smotz »
This didnt work.
When I set ReefAngel.LightsOnPorts = FugelightBit;
and press "lights on" the device on port 8 of my first relay box is activated (which is my fan).
Please advise..
[code]////  Port 1			Heater
////  Port 2			ATO pump
////  Port 3			Reactor Pump
////  Port 4			Protien Skimmer
////  Port 5			Return Pump
////  Port 6			Wavemaker
////  Port 7                    UV Sterilizer
////  Port 8                    Fan
////  BOX 1 PORT 8              Fuge Light
#define Wave Port6
#define Fan  Port8
static byte wpMode;
static byte wpWavStr;
static byte wpWavOff;
  // Use T1 (SUMP) probe as temperature and overheat functions
  ReefAngel.Relay.On( Return );
  ReefAngel.Relay.On( Reactor );
  ReefAngel.Relay.On( Wave );
  ReefAngel.StandardHeater( Heater );
  ReefAngel.StandardATO( Topoff );
  ReefAngel.MoonLights( Fugelight );
  ReefAngel.StandardFan( Fan );
  ReefAngel.LCD.DrawText(0,255,20,80,"Joe's Reef Tank");
  ReefAngel.Relay.DelayedOn(Skimmer,2);
  ReefAngel.Relay.DelayedOn(UVlight,1);
  ReefAngel.DCPump.FeedingSpeed=30;
  //if (ReefAngel.DCPump.Mode==Custom) ReefAngel.DCPump.UseMemory = false;
  //else ReefAngel.DCPump.UseMemory = true;
  // Custom Wave Routine
  if (ReefAngel.DCPump.Mode==Custom) {
    // set the wpMode
    if ( (hour() >= 5) && (hour() < 8) )   wpMode=1;       // from 5am - 8am
    if ( (hour() >= 8) && (hour() < 11) ) wpMode=2;      // from 8am - 11am
    if ( (hour() >= 11) && (hour() < 14) ) wpMode=3;     // from 11a - 2pm
    if ( (hour() >= 14) && (hour() < 17) ) wpMode=2;     // from 2pm - 5pm
    if ( (hour() >= 17) && (hour() < 20) ) wpMode=1;     // from 5pm - 8pm
    if ( (hour() >= 20) && (hour() < 23) ) wpMode=2;     // from 8pm - 11p
    if ( (hour() >= 23) && (hour() < 2) ) wpMode=3;      // from 11pm - 2am
    if ( (hour() >= 2) && (hour() < 5) ) wpMode=2;       // from 2am - 5am
    if (wpMode=1) wpWavStr=45;
    if (wpMode=2) wpWavStr=50;
    if (wpMode=3) wpWavStr=55;
    //Set the Wave OffSet
    wpWavOff=12;
    //if (ReefAngel.DisplayedMenu==FEEDING_MODE) ReefAngel.PWM.SetDaylight(30);
    //else
    ReefAngel.PWM.SetDaylight( ReefCrestMode(wpWavStr,wpWavOff,true) );
    ReefAngel.PWM.SetActinic(wpWavStr);
  // end Custom Wave Routine
    //  Only turn on UV Sterilizer between 11pm and 5am
  if ( (hour() >= 5) && (hour() < 23) )  // from 5a - 11p
    ReefAngel.Relay.Off(UVlight);
  else ReefAngel.Relay.On(UVlight);
  ReefAngel.Portal( "Smotz" );
  // Salinity
  ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
  ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
  // Relay Expansion
  ReefAngel.LCD.DrawOutletBox( 12, 102, TempRelay );
  //draw the mode on the screen
  char buf[16];
  if (ReefAngel.DisplayedMenu==FEEDING_MODE) sprintf(buf,"Pumps at %d%%",ReefAngel.DCPump.FeedingSpeed);
  else sprintf(buf,"RC %d%% +/- %d%%",wpWavStr,wpWavOff);
  ReefAngel.LCD.DrawText(0,255,15,52,buf);
[/code]
I'd have to check the code to confirm but try this
ReefAngel.LightsOnPortsE[0] = FugeLightBit;
Yep, confirmed. And this is why the Port8Bit variable is the same because the variable you are assigning it to is different for the other relay box.
Smotz
Post by Smotz »
lnevo wrote:Yep, confirmed. And this is why the Port8Bit variable is the same because the variable you are assigning it to is different for the other relay box.
If I want to address expansion ports do I add E [0] to it?
Sent from my SCH-I605 using Tapatalk 4 Beta
Correct :)
And if you have more expansion relay boxes, it would be E[1], E[2] and so on.
