Coding for Fresh Water Tank.
Ask in here.
abhi_123
Post by abhi_123 »
Hi I am planning to use my reef angel controller to control my 2 planted tank.
i will be using this code
// Autogenerated file by RAGen (v1.2.2.171), (06/02/2013 11:59)
// RA_060213_1159.ino
// This version designed for v0.9.0 or later
/* The following features are enabled for this File:
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <ReefAngel.h>
    ReefAngel.Relay.On(Port5);
    ReefAngel.Relay.On(Port7);
    ReefAngel.MHLights(Port1);
    ReefAngel.MHLights(Port2);
    ReefAngel.StandardFan(Port3);
    ReefAngel.StandardFan(Port4);
    ReefAngel.Wavemaker1(Port6);
    ReefAngel.StandardHeater(Port8);
    ReefAngel.Portal("abhi_123", "75HRSNAHMLYUS");
Port no. 1 & 2 will be used for the lights, 3 & 4 will be either chiller or fan, 5 & 6 are filteration, 7 will be to control Co2 or Ph, 8 will be for heater.
I want to set the timing of light between 9:00 am to 6:00 pm, fans & heaters to be set as to maintain temp between the range of 24 degree to 27 degree, ph to be around 6.8.
What amendment is required in above code to work as it.
rossbryant1956
Re: Coding for Fresh Water Tank.
Post by rossbryant1956 »
I use the wizard as a starting place for all my new code ideas, then edit it (or ask questions) to get that last mile done. Try it. Thx
abhi_123
Post by abhi_123 »
Thanks for the advice but tool option of my arduino is not opening.
