There is a wealth of knowledge here, but it's scattered all over.
How about a new section, where each post is a single piece of code for solving a problem? No discussion (can be put somewhere else). That way things would be easy to search.
Something like this.
Turn Lights Down on Overheat
This will dim your LED's when the temperature hits 83 and return them to normal when the temperature drops below 80. Put it in the loop section.
// Lights down on overheat
static boolean overheat=false;
if (ReefAngel.Params.Temp[T1_PROBE] >= 830) overheat=true;
if (ReefAngel.Params.Temp[T1_PROBE] <= 800) overheat=false;
if (overheat)
ReefAngel.PWM.SetActinic(15);
ReefAngel.PWM.SetDaylight(15);
I'm not a big wiki user, but if someone wants to make the sections, etc it would be pretty straight forward to filling in the snippets. I know there's like 5 ways to do ATO and 100 ways to do Feeding Modes, etc. I just need a structure to follow
