The original code looked something like this:
if (hour()>=10 && hour()<21)
ReefAngel.PWM.SetDaylight(ReefCrestMode(50,50,true));
else if (hour()>=9 && hour()<22)
ReefAngel.PWM.SetDaylight(ReefCrestMode(25,16,true));
ReefAngel.PWM.SetDaylight(ReefCrestMode(0,0,true));
I've put it into multiple lines so you can see the arguments more clearly.
ReefCrestMode(
PWMSlope(9,0,22,0,25,50,60,0),
PWMSlope (9,0,22,0,16,50,60,0),
true
ReefAngel.PWM.SetDaylight(ReefCrestMode(PWMSlope(9,0,22,0,25,50,60,0),PWMSlope (9,0,22,0,16,50,60,0),true));
Except now, instead of static numbers for the 2 numeric arguments to ReefCrestMode, we've replaced them with the PWMSlope. Here are the arguments to PWMSlope. So what I did was say from 9am to 10pm we will go from 25% to 50% and it will take 60 minutes to get there. Otherwise we will use 0. So that last 0 is your last else. You could set it tthat last argument for whatever you want for your night mode to be.
Here's the definition for the PWMSlope command.
byte PWMSlope (
byte startHour,
byte startMinute,
byte endHour,
byte endMinute,
byte startPWM,
byte endPWM,
byte Duration,
byte oldValue
You could also do the same thing using the PWMParabola as well. The function is pretty much the same, just without the duration argument.
byte PWMParabola (
byte startHour,
byte startMinute,
byte endHour,
byte endMinute,
byte startPWM,
byte endPWM,
byte oldValue
