WP40 on the ATO PWM & Custom code
Re: WP40 on the ATO PWM & Custom code
I think you can do once, but just in case keep it everytime you use digitalWrite, just because the ATO port is setup as input and not as output.
Roberto wonder if that may be the problem for the person who had issue in feeding/wc mode with the lowAto.
Well I tried this
and got an error on "else" - it says "there is not an if" before
so I just changed it to this, and it's working fine
StartFeeding=now(); // if we entered feeding mode, register what time it was.
if (now()-StartFeeding > 1800 && now()-StartFeeding < 5400) // if feeding started between 1800 and 5400 seconds
pinMode(lowATOPin,OUTPUT)
analogWrite(lowATOPin,100*2.55);
analogWrite(lowATOPin,75*2.55);
ReefAngel.StandardLights( Port1,14,0,19,0 );
ReefAngel.StandardLights( Port2,15,0,20,0 );
ReefAngel.StandardLights( Port3,19,55,22,0 );
ReefAngel.StandardLights( Port4,14,0,20,15 );
ReefAngel.StandardHeater( Port5,780,785 );
ReefAngel.StandardFan( Port6,780,800 );
ReefAngel.StandardLights( Box1_Port5,22,0,16,0 );
pinMode(lowATOPin,OUTPUT);
static time_t StartFeeding=0;
analogWrite(lowATOPin,60*2.55);
What's the difference between the regular cables and the ATO cable for jebao?
You have to remove a resistor (surface mount) on the cable for it to work properly with the 5V ATO signal. There's a thread around here somewhere that points it out.
Thanks, found it.
