WP40 on the ATO PWM & Custom code
kimacom
Re: WP40 on the ATO PWM & Custom code
Post by kimacom »
this is awesome thread,
that helps me a lot to understand and use it.
thanks much guys
ganjero
Post by ganjero »
is there a way to check if this is working? if the speed is ramping up and down? will the portal ato low level change colors when running this?
Also,
How would I change this code for a pump connected to the ATO port?
static time_t StartFeeding=0;
                StartFeeding=now(); // if we entered feeding mode, register what time it was.
              if (now()-StartFeeding > 1800 && now()-StartFeeding < 5400) // if feeding started between 1800 and 5400 seconds
                ReefAngel.PWM.SetActinic(45);
ganjero
Post by ganjero »
any input on the above?
The code you posted is for feeding mode.
Not sure what you are asking.
The way to test is load into the controller and check your pump.
Amos Poh
Post by Amos Poh »
( PWMParabola(3,0,2,59,30,75,0), PWMParabola(3,0,2,59,12,25,0),true) );
Hi can anyone explain what the number means so i can alter to my preference?
ganjero
Post by ganjero »
rimai wrote:The code you posted is for feeding mode.
Sorry if I was not clear. This code controls a pump that run a 45% all the time, and at 100% for one hour starting 30min after triggering feed mode.
My question is how do I modify this code to do this for a pump controlled through the ATO port instead of the Actinic port as shown in the code.
Thank you,
It's in the OP.
Use something like this to set the ATO port to what you want:
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin,45*2.55);
The example above sets it to 45%
Amos Poh wrote:( PWMParabola(3,0,2,59,30,75,0), PWMParabola(3,0,2,59,12,25,0),true) );
Check here:
http://www.easte.net/RA/html/_globals_8 ... de5873f8d6
ganjero
Post by ganjero »
rimai wrote:It's in the OP.
Does this
need to be written everetime I modify the speed? or can I write once somewhere in the code and then do different speeds with the second line? Like this
The xxxxxxx are other lines in the code
xxxxxxxx
         xxxxxxx
         xxxxxxxx
         xxxxxxxx
               analogWrite(lowATOPin,100*2.55);
                analogWrite(lowATOPin,75*2.55);
Thank you again
I'm pretty sure it only needs to be done once.
I think you can do once, but just in case keep it everytime you use digitalWrite, just because the ATO port is setup as input and not as output.
Roberto wonder if that may be the problem for the person who had issue in feeding/wc mode with the lowAto.
Humm... not sure
ganjero
Post by ganjero »
Well I tried this
and got an error on "else" - it says "there is not an if" before
so I just changed it to this, and it's working fine
            ReefAngel.StandardLights( Port1,14,0,19,0 );
            ReefAngel.StandardLights( Port2,15,0,20,0 );
            ReefAngel.StandardLights( Port3,19,55,22,0 );
            ReefAngel.StandardLights( Port4,14,0,20,15 );
            ReefAngel.StandardHeater( Port5,780,785 );
            ReefAngel.StandardFan( Port6,780,800 );
            ReefAngel.StandardLights( Box1_Port5,22,0,16,0 );
                analogWrite(lowATOPin,60*2.55);
89delta
Post by 89delta »
What's the difference between the regular cables and the ATO cable for jebao?
You have to remove a resistor (surface mount) on the cable for it to work properly with the 5V ATO signal. There's a thread around here somewhere that points it out.
89delta
Post by 89delta »
Thanks, found it.
