For anyone looking to implement some of these elements with the new DCPump class, please take a look at what I did with Paulturner911.
http://forum.reefangel.com/viewtopic.php?p=29100#p29100
In the custom mode for that INO we implemented a daily change of the mode from a set array of choices. We extended the Feeding Mode Speed past the end of Feeding Mode to give the corals more time grabbing food in the water column. Then after that we kick off Nutrient Transport for 60 minutes.
There is also the Night Mode setting in the same block. The night and feeding stuff will work on any mode and the random selection only when we've chosen Custom.
I started a new thread since these things are commonly asked and not to muddy up Paul's thread for those with specific questions and how do I's
DCPump Custom, Night, Extended Feeding Modes
Re: DCPump Custom, Night, Extended Feeding Modes
Here's the code excerpt to make it easier for everyone. It's pretty straight forward and is a great reference for anyone who wants to use the new DCPump routines and have scheduled modes, etc.
// Add random mode if we set to Mode to Custom in portal
static int rmode;
byte modes[] = { ReefCrest, TidalSwell, ShortPulse, NutrientTransport };
if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
changeMode=false;
static unsigned long feeding;
if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
feeding = now();
if (now()-feeding<=900) {
// 30 minutes after feeding mode. Pump is off
ReefAngel.DCPump.Speed=0;
} else if (now()-feeding<=(900+3600)) {
// First 30 minutes pump is off, Next 60 is NTM
ReefAngel.DCPump.Mode=NutrientTransport;
ReefAngel.DCPump.Speed=InternalMemory.DCPumpSpeed_read(); // Resume previous speed
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
// Night mode (go to 30%)
ReefAngel.DCPump.Mode=Constant;
ReefAngel.DCPump.Speed=30;
} else if (InternalMemory.DCPumpMode_read()==11) {
ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
} else {
