ReefAngel.Relay.DelayedOn( Port8,10 );Apparently the code for the Water Level Expansion Unit and the ATO override the code above.
ReefAngel.WaterLevelATO(Port8,720,32,32); // Enable ATO the ATOCurrent Code;
ReefAngel.StandardLights( Port1,12,0,22,0 );
ReefAngel.StandardLights( Port2,13,0,21,0 );
ReefAngel.Relay.Set( Port3, !ReefAngel.Relay.Status( Port1 ) );
ReefAngel.StandardLights( Port5,13,0,21,0 );
ReefAngel.Relay.Set(Port7,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
ReefAngel.Relay.Set(Port6,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
if (ReefAngel.Relay.Status(Port7)) // Check to see if port 7 is on and update time is empty
ATOUpdate = now(); // If so, set the update time to now
if (now() - ATOUpdate < 120) // If it hasnt been 120 seconds turn off the port
ReefAngel.WaterLevelATO(Port8,720,0,1);
if (ReefAngel.DCPump.Mode==Custom)
ReefAngel.PWM.SetActinic( ElseMode(40,20,true ));// ElseMode on sync mode, 40 +/- 20%
if( ReefAngel.DisplayedMenu==FEEDING_MODE ) ReefAngel.PWM.SetActinic(20);
if (hour()<12 || hour()>=22) ReefAngel.PWM.SetActinic(30);Code: Select all
