Date and time issue
Re: Date and time issue
Well how about that. Guess I didn't need the upgraded board.
So this is interesting... The old board is keeping time fine. When I came home from work, the LEDs didn't look right - too much blue. So I check the time and it was spot on. The screen showed the right led levels. I unplugged the dimmer box and only two sets of the four LEDs lit. Plugged it back in and nothing lit. I played with it I bit and then decided to check if the new board would light them. Switched the boards and viola they worked. Switched the boards back and they are working again.
I have no ideal what happened but wanted to see if anyone had some thoughts?
