Customizing Delayed start
Re: Customizing Delayed start
What decides is how the function is written. DelayedOn uses minutes. So just use 30.
Aside from convenience and preference as Roberto pointed out, it is also determined by memory usage (byte vs int) and what makes sense. When writing functions now() returns seconds so thats why it's easy. But looking at delayed on it was determined that no one needed to delay in seconds only so minutes were used. This also makes it easy to store the DelayedOn default time in memory because a byte can be used instead of an int (100% savings!!)
To represent 15 minutes in seconds would be 900 and require an int for storage instead of a byte. It may not seem like much but they all add up.
Yep. When I wrote DelayedOn, the delay of seconds didn't seem appropriate because most people wanted a 1 or 2 minute (maybe even 5 minute) delay so their tanks would fill back up before the power heads started working (like in my case).
Plus, like Lee said, it's a storage issue as well as a convenience.
Now, if we were to look at the WavemakerRandom function, it makes more sense to use seconds because you may want it to run every 30 seconds before alternating or 90 seconds or something along those lines. You can't code in 1.5 for a a minute and a half, so you would be better suited for 90 seconds.
ganjero
Post by ganjero »
Make sense, so the delayon function is in the libraries based in minutes. Thanks
Why is my skimmer coming back on after 15min instead of an hour in my code?
            ReefAngel.FeedingModePorts = Port7Bit | Port8Bit;
            ReefAngel.WaterChangePorts = Port7Bit | Port8Bit;
            ReefAngel.WaterChangePortsE[0] = Port3Bit;
            ReefAngel.LightsOnPorts = Port1Bit | Port4Bit;
            ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit;
            InternalMemory.OverheatTemp_write( 851 );
            //Feeedin mode length
            ReefAngel.Timer[FEEDING_TIMER].SetInterval(300);
            ReefAngel.Relay.On( Box1_Port1);
            ReefAngel.StandardLights( Port1,14,0,19,0 );
            ReefAngel.StandardLights( Port2,15,0,20,0 );
            ReefAngel.StandardLights( Port3,19,55,22,0 );
            ReefAngel.StandardLights( Port4,14,0,20,15 );
            ReefAngel.StandardHeater( Port5,780,785 );
            ReefAngel.StandardFan( Port6,780,800 );
            ReefAngel.Relay.DelayedOn( Port7,60 );
            ReefAngel.StandardLights( Box1_Port5,22,0,16,0 );
            ////disable ReefAngel.PWM.SetDaylight( ElseMode(70,30,true ));                     // ElseMode on sync mode, 70 +/- 30%
            ReefAngel.PWM.SetDaylight( ReefCrestMode(70,30,true) ); // ReefCrest at 70% +/- 30% on sync mode
             //// Jebao sump pump runs at 45% unless feeding, then a 30min runs at 100% 1hr.
             static time_t StartFeeding=0;
                StartFeeding=now(); // if we entered feeding mode, register what time it was.
              if (now()-StartFeeding > 1800 && now()-StartFeeding < 5400) // if feeding started between 1800 and 5400 seconds
                ReefAngel.PWM.SetActinic(45);
            ///// Delay Start Turn off on Booting - Start
            static unsigned long startTime=now();
            if (startTime==LastStart) {
              ReefAngel.Relay.On(Port7);
              ReefAngel.Relay.DelayedOn(Port7);
            ///// Delay Start Turn off on Booting - End
            ReefAngel.Portal( "ganjero" );
            int x,y;
            // Relay Expansion
           //// Jebao Else Mode - Start
              static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
              static int Delay = random( 500, 3000);           // Set the initial delay
              static int NewSpeed = MidPoint;                  // Set the initial speed
              static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
              if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
                Delay=random(500,5000);                        // If so, come up with a new delay
                int ChangeUp = random(Offset);                 // Amount to go up or down
                if (random(100)<50)                            // 50/50 chance of speed going up or going down
                LastChange=millis();                           // Reset the time of the last change
              if (WaveSync)
                return NewSpeed;
                return AntiSpeed;
            //// Jebao Else Mode - End
Looks good. As I said RAStart didn't work for me for some reason... may revisit it later...
You have 2 Port7 referenced in two places.
And
The second one will always override the 1st one.
The last one is using InternalMemory to set the delay. Check on the portal your default delay may be 15 minutes...
ganjero
Post by ganjero »
That's it! learning more everyday :oops: so should I delete the first reference and just adjust the delay in portal so I can keep the code that prevents triggering the delay on reboots?
Can I also fix this by deleting the first reference and just adding the time on the second reference? like this:
              ReefAngel.Relay.DelayedOn(Port7,60);
Thank you
Yes, you got it :)
If you just take out the ,60 you will have best of both worlds. Set the delay time in the portal and have it not delay on reboots.
ganjero
Post by ganjero »
You mean delete
 ReefAngel.Relay.DelayedOn( Port7,60);
and leave this one like this:
Yep
ganjero
Post by ganjero »
Great, Thanks again
