I recently made some changes to my hardware config and thought that it would be an opportune time to initialise the controller to try fix this issue. (I had to revert to 1.0.7 lib because of "sketch too big" with newer libs)
So, I initialised, ran the wizard and generated my code. uploaded and all seems to work well. EXCEPT!!!! (dum dum dummmmmm)
The Vortech still has this exact same issue with feed/Water change mode. It doesnt return to full power unless I reboot the Vortech.
I also set my Tunze (Port 5) to alternate on/off every 8 min, but it doesnt seem to be working either
Please help
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.DayLights( Port1 );
ReefAngel.DayLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.StandardHeater( Port4 );
ReefAngel.Wavemaker1( Port5 );
ReefAngel.RF.UseMemory = true;
ReefAngel.Portal( "poiromaniax" );
int x,y;
// pH Expansion
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,66, 100 );
