My PDE has code to run the Vortech pumps through the memory function and then switch to feed mode, when selected, Nutrient Transport Mode after feed mode for 10 minutes and also a night mode. I would like to replicate these settings, but realize the modes may not transfer to the closed loops the same as they do to the MP and WP pumps. I haven't been able to test night mode yet because I haven't been through a day, but when Feed Mode is selected the pumps stops and after feed mode there doesn't seem to be any difference with the NTSP mode to the Reef Crest.
What I am looking for in the NTSP mode is to help the Vortech kick up any debris that has landed on the sand bed and rock to have another chance at being eaten or to flow down the overflow. The feed mode needs to be a slight flow just to move things around a little rather than being off all together. Night mode I have selected Reef Crest with a lighter flow, still random, but a more gentle variation.
I'm not concerned about picking up the settings from the portal or memory, but this might make life easier, but I definitely want to keep the feed mode, night mode and some form of NTSP mode after feeding, which can revert back to portal or memory settings after.
Here is my PDE:
// This version updated for v1.0.3 or later
The following features are enabled for this File:
#define DisplayImages
#define OverheatSetup
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define SaveRelayState
#define WDT
#define PWMEXPANSION
#define CUSTOM_MAIN
#define COLORS_PDE
#define SALINITYEXPANSION
#define RFEXPANSION
#define FONT_8x8
#define FONT_8x16
Ports assignment:
Port1 - Fuge Light
Port2 - Avast ATO
Port3 - Heater(s)
Port4 - Kalk Reactor
Port5 - Avast Schwabble
Port6 - Closed Loop Pump
Port7 - Skimmer
Port8 - Return Pump
//--------------------------------------------------- Start of Global Variables ---------------------------------------------------
// Globals Needed for RF Mode on Custom Menu
byte vtmode;
byte vtspeed;
// Globals Needed for Params on Custom Main
byte x,y;
int v;
byte vtechmode;
byte vtechspeed;
boolean bFeeding=false;
//------------------------------------------------------ End of Global Variables --------------------------------------------------
//----------------------------------------------------------- Custom Menu ---------------------------------------------------------
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding";
prog_char menu1_label[] PROGMEM = "Water Change Pause";
prog_char menu2_label[] PROGMEM = "Vortech Mode";
prog_char menu3_label[] PROGMEM = "Vortech Speed";
prog_char menu4_label[] PROGMEM = "Lights On";
prog_char menu5_label[] PROGMEM = "Lights Off";
prog_char menu6_label[] PROGMEM = "Overheat Clear";
prog_char menu7_label[] PROGMEM = "PH Calibration";
prog_char menu8_label[] PROGMEM = "Salinity Calibration";
menu0_label, menu1_label, menu2_label,
menu3_label, menu4_label, menu5_label,
menu6_label, menu7_label, menu8_label
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
vtmode++;
vtechmode++;
if (vtmode>6)
vtmode=0;
vtechmode=0;
InternalMemory.RFMode_write(vtmode); // Set the Internal Memory Setting for RF Mode
ReefAngel.RF.SetMode(vtmode, InternalMemory.RFSpeed_read(), InternalMemory.RFDuration_read());
void MenuEntry4()
vtspeed+=10;
vtechspeed+=10;
if (vtspeed>100)
vtspeed=0;
vtechspeed=0;
InternalMemory.RFSpeed_write(vtspeed); // Set the Internal Memory Setting for RF Speed
ReefAngel.RF.SetMode(InternalMemory.RFMode_read(), vtspeed, InternalMemory.RFDuration_read());
void MenuEntry5()
ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
ReefAngel.Relay.Write();
void MenuEntry6()
ReefAngel.Relay.RelayMaskOn = 0;
void MenuEntry7()
ReefAngel.OverheatClear();
void MenuEntry8()
ReefAngel.SetupCalibratePH();
void MenuEntry9()
ReefAngel.SetupCalibrateSalinity();
//--------------------------------------------------------- End Custom Menu -------------------------------------------------------
//---------------------------------------------Custom Main for PWM Expansion Module------------------------------------------------
//Top Banner
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 9, 3, "WISEGUYS' REEF", Font8x16);
ReefAngel.LCD.Clear(DefaultFGColor,3,21,126,21);
// Display T1 Header Text
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,10,25,"Tank");
char text[7];
// Display the T1 Temp Value
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 4, 35, text, Font8x16);
// Display the Salinity Header Text
ReefAngel.LCD.DrawText(COLOR_CRIMSON,255,55,25,"Sal.");
// Display the Salinity Value
ReefAngel.LCD.DrawLargeText(COLOR_CRIMSON, 255, 57, 35, text, Font8x16);
// Display pH Header Text
ReefAngel.LCD.DrawText(COLOR_INDIGO,255,105,25,"pH");
// Display pH Value
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 94, 35, text, Font8x16);
//Display Alternate Temp Parameters
ReefAngel.LCD.DrawText(0,255,8,54,"Sump");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_CORNFLOWERBLUE, 36, 54, 10);
ReefAngel.LCD.DrawText(0,255,72,54,"Hood");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_CORNFLOWERBLUE, 100, 54, 10);
// Display EcoSmart Mode Value & Speed %
ReefAngel.LCD.Clear(DefaultFGColor,3,65,126,65);
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 17, 69, "Ecotech Mode");
ConvertNumToString(text, vtechspeed, 1);
if (vtechmode == 0)
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,1,80,"Constant - ", Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,97,80,text, Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,121,80,"%", Font8x16);
else if(vtechmode == 1)
ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,1,80,"Lagoon - ", Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,97,80,text, Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,121,80,"%", Font8x16);
else if (vtechmode == 2)
ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,1,80,"Reef Crest -", Font8x16);
else if (vtechmode == 3)
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,1,80,"Short Pulse-", Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,97,80,text, Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,121,80,"%", Font8x16);
else if (vtechmode == 4)
ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,1,80,"Long Pulse -", Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,97,80,text, Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,121,80,"%", Font8x16);
else if (vtechmode == 5)
ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,1,80,"Nutrient TM-", Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,97,80,text, Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,121,80,"%", Font8x16);
else if (vtechmode == 6)
ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,1,80,"Tidal Swell-", Font8x16);
else if (vtechmode == 9)
ReefAngel.LCD.DrawLargeText(COLOR_BLACK,255,1,80,"Night - ", Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_BLACK,255,97,80,text, Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_BLACK,255,121,80,"%", Font8x16);
// Display Main Relay Box
ReefAngel.LCD.Clear(DefaultFGColor,3,99,126,99);
ReefAngel.LCD.DrawOutletBox(13, 102, TempRelay);
//Draw Date & Time
ReefAngel.LCD.Clear(DefaultFGColor,3,116,126,116);
ReefAngel.LCD.DrawDate(6, 119);
void DrawCustomGraph() // Not Used
//------------------------------------------------------ End Custom Main ----------------------------------------------------------
//-------------------------------------------------------- Begin Setup ------------------------------------------------------------
ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); //Intialize Custom Menu
vtmode=InternalMemory.RFMode_read();
vtspeed=InternalMemory.RFSpeed_read();
vtechmode=InternalMemory.RFMode_read();
vtechspeed=InternalMemory.RFSpeed_read();
ReefAngel.FeedingModePorts = Port2Bit | Port7Bit | Port6Bit; // Turn off Skimmer, ATO and Close Loop when feeding mode is activated
ReefAngel.WaterChangePorts = Port2Bit | Port7Bit | Port8Bit; // Turn off Return Pump, Skimmer & ATO when water change mode is actived
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit;
ReefAngel.TempProbe = T1_PROBE; // Use T1 probe as temperature and overheat functions
InternalMemory.OverheatTemp_write( 850 ); // Set the Overheat temperature setting
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port8);
//---------------------------------------------------------- End Setup ------------------------------------------------------------
//--------------------------------------------------------- Begin Loop ------------------------------------------------------------
// Specific functions
ReefAngel.Relay.DelayedOn(Port7, 2); // Turn on Port 7 (Skimmer) with 2 minute delay
ReefAngel.Relay.DelayedOn(Port2, 10); // Turn on Port 2 (Avast ATO) with 10 minute delay
ReefAngel.StandardLights(Port1,21,0,9,00); //Fuge Light on at night
ReefAngel.StandardHeater(Port3,790,800); // Standard Heater Using Internal Memory
ReefAngel.DosingPumpRepeat(Port5,0,360,60); //Turn Schwabble on for 1 minute every 4 hours
// Fan Speed Functions
signed int HoodFanSpeed;
HoodFanSpeed=map(ReefAngel.Params.Temp[T3_PROBE],750,1000,25,100); // Calculate Hood Fan speed
HoodFanSpeed=constrain(HoodFanSpeed,0,100);
ReefAngel.PWM.SetChannel(0,HoodFanSpeed);
signed int SumpFanSpeed;
SumpFanSpeed=map(ReefAngel.Params.Temp[T2_PROBE],750,850,25,100); // Calculate Sump Fan speed
SumpFanSpeed=constrain(SumpFanSpeed,0,100);
ReefAngel.PWM.SetChannel(1,SumpFanSpeed);
ReefAngel.PWM.SetDaylight(ReefCrestMode(80,20,true));
------------------------------------------------ Start Time-of-Day Based Functions ----------------------------------------------
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ These are the mode numbers for the RF Expansion Module for reference ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
#define Constant 0
#define Random1 1 // Lagoonal
#define Random2 2 // Reef Crest
#define ShortWave 3
#define LongWave 4
#define Smart_NTM 5 // Nutrient Transport Mode
#define Smart_TSM 6 // Tidal Swell Mode
#define Feeding_Start 7
#define Feeding_Stop 8
#define Night 9
#define Slave_Start 97
#define Slave_Stop 98
#define None 99
RF Mode = http://YOURIPADDRESS:2000/mb855,X
RF Speed = http://YOURIPADDRESS:2000/mb856,X
RF Duration = http://YOURIPADDRESS:2000/mb857,X
//---------------------------------------------- Start RF Control Mode for Daytime, Night and Feeding ---------------------------
if (hour() >=9 && hour() < 21)
if (vtechmode == 9)
ReefAngel.RF.UseMemory=true;
vtechmode = InternalMemory.RFMode_read();
vtechspeed = InternalMemory.RFSpeed_read();
bFeeding=true;
ReefAngel.PWM.SetDaylight(50);
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && bFeeding)
bFeeding=false;
ReefAngel.Timer[1].SetInterval(600); // Timer for 10min
ReefAngel.Timer[1].Start();
ReefAngel.RF.UseMemory=false;
ReefAngel.PWM.SetDaylight(NutrientTransportMode(50,100,500,true));
ReefAngel.RF.SetMode(Smart_NTM,100,6);
vtechmode = 5;
vtechspeed = 100;
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && ReefAngel.Timer[1].IsTriggered())
ReefAngel.PWM.SetDaylight(ReefCrestMode(50,5,true));
vtechmode = 9;
vtechspeed = 15;
//------------------------------------------------ End RF Control Mode for Daytime, Night and Feeding -----------------------------
ReefAngel.Portal("mvwise");
//--------------------------------------------------------------- End Loop --------------------------------------------------------
