Verification Error
Re: Verification Error
Ok, when you can, please try uploading a couple different codes to see if you get the same error and write down the address that it has failed, if it does.
Ok, if different INO files have different errors, do you want me to attach the INO file with the error number?
Yup, same memory value everytime.
Attempted to downgrade to the 1.0.6 libraries, still failed.
Then went back to the libraries who's date looked most like the last time I updated, and ended up on 1.0.4.
It uploaded!
Now, I am going on vacation so I won't be here over the weekend. My code as far as feedmode looks good, and won't lock anythign up now will it?
It uploaded!
Binary sketch size: 30,134 bytes (of a 32,256 byte maximum)
If you would like, you can send the unit back for analysis.
It looks like it may have to be repaired/replaced.
