Putting protein skimmer on a schedule
Seagals
Post by Seagals »
Hi - I would like to have my skimmer on Port 1 go on at 8am and turn on a 9pm and I need some guidance before I mess with my code.
right now the skimmer is always on code as follows:
ReefAngel.Relay.On( Port1 );//Protein skimmer
ReefAngel.Relay.On( Port7 );//Chiller
ReefAngel.Relay.On( Port8 );//Main pump
Question - if I am now putting the skimmer on a schedule should I remove port 1 (skimmer) from this section??
Now the schedule part - if you would please confirm I added the code correctly before I mess up my existing code......
ReefAngel.ProteinSkimmer( Port1,8,0,21,00);
ReefAngel.StandardLights( Port2,9,0,21,30 );
ReefAngel.StandardLights( Port3,11,0,20,30 );
ReefAngel.StandardLights( Port4,9,0,21,30 );
ReefAngel.Wavemaker( Port5,960 );
ReefAngel.Relay.Set( Port6, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.PWM.SetDaylight( PWMSlope(11,0,20,25,5,70,120,5) );
ReefAngel.PWM.SetActinic( PWMSlope(9,0,21,30,15,88,60,20) );
static unsigned long lastATOCheck=millis();
if (!ReefAngel.LowATO.IsActive()) lastATOCheck=millis();
if (ReefAngel.LowATO.IsActive() && (millis()-lastATOCheck>2000)) ReefAngel.Relay.RelayMaskOff&=~(Port8Bit | Port7Bit | Port1Bit);
if ( (hour()>=8 && hour()<20))//wavemakers on at 8am and off at 8pm
static unsigned long nexttoggle=now();
static boolean state=false;
int cycle=nexttoggle-now();
ReefAngel.Relay.Set(Port5,state);
if (cycle<0)
nexttoggle+=random(960,1020);//tunzes on for 15-16 mins
state=!state;
if (cycle<10)//10 sec overlap
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
Thanks in advance for your help.
Re: Putting protein skimmer on a schedule
Yes, remove the Relay.On, but use StandardLights not ProteinSkimmer
ReefAngel.Relay.StandardLights( Port1,8,0,21,0 );//Protein skimmer
Seagals
Post by Seagals »
Hey - Inevo - got the idea from the MR site - I wanted to give it a try see how the tank does with less Skimmer use....The following is the code but when I verified it I got the following error:
'class Relayclass' has no member named 'StandardLights'
Sorry guys thought I couold give it try on my own but I need your review of the following and offer a solution. Thanks
#include <avr/pgmspace.h>
prog_char menu3_label[] PROGMEM = "Overheat Clear";
prog_char menu5_label[] PROGMEM = "Version";
prog_char menu6_label[] PROGMEM = "Clear Low Water";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label };
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.DisplayVersion();
void MenuEntry7()
ReefAngel.Relay.RelayMaskOff=255;
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
if (cycle<0)
state=!state;
ReefAngel.Portal( "Seagals" );
Sorry my bad. Take out the relay part. Make it look like your other StandardLights calls
Seagals
Post by Seagals »
ok verified and uploaded - thanks
