A while back lnevo gave me some code to keep the ATO from kicking in for 10 min after a water change.
It never worked the way it should but it didn't cause any problems either.
Last week I switched my ATO Pump from the Relay to the power expansion unit and since then it seems that it is randomly turning on for a period of 30 sec or so.
This has been messing with my salinity. Bringing it down to about 29ppt from 35ppt. Not good.
To keep the ATO from turning on I had unplugged the ATO for a day or so and them I added this line that Roberto gave me a while back, but never used.
if (ReefAngel.Params.Salinity<335) ReefAngel.Relay.Off(ATO_Pump );
I just did a water change and again the ATO turned on 2 time for about 30 seconds each when everything was in the correct parameters. Water level was 32 or above and salinity was 34.8.
Right now I have the ATO Pump unplugged, but as far as I can see it seems to be turning on after the pumps come back on or after a reboot of a code update.
My full code is below.
Thanks so much, in advance, for your help.
// Define Relay Ports by Name
#define Actinic_Lights 1
#define Day_Lights 2
#define Unused 3
#define Pumps 4
#define Sump_Fan 5
#define DeNit_Pump 6
#define DeNit_Doser 7
#define Unused 8
#define ATO_Pump Box1_Port1
#define Moon_Lights Box1_Port2
#define Unused Box1_Port3
#define Unused Box1_Port4
#define Unused Box1_Port5
#define Unused Box1_Port6
#define Unused Box1_Port7
#define Unused Box1_Port8
unsigned long ATOUpdate=0;
//Set Standard Menu
ReefAngel.AddStandardMenu();
ReefAngel.DCPump.FeedingSpeed=20;
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
ReefAngel.StandardLights( Day_Lights,13,0,21,0 );
ReefAngel.Relay.Set( Moon_Lights, !ReefAngel.Relay.Status( Actinic_Lights ) );
ReefAngel.StandardLights( Sump_Fan,13,0,21,0 );
ReefAngel.Relay.Set(DeNit_Doser,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
ReefAngel.Relay.Set(DeNit_Pump,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
// ReefAngel.Relay.DelayedOn( ATO_Pump,10 );
// ReefAngel.WaterLevelATO(ATO_Pump,720,32,32); // Enable ATO the ATO
//Disable ATO if Salinity is below 33.5
if (ReefAngel.Params.Salinity<335) ReefAngel.Relay.Off(ATO_Pump);
// Delay WL ATO after water change.
static time_t wcTimer;
if (now()-wcTimer > 0 && now()-wcTimer < 600) {
ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
if (ReefAngel.Relay.Status(DeNit_Doser)) // Check to see if is on and update time is empty
ATOUpdate = now(); // If so, set the update time to now
if (now() - ATOUpdate < 120) // If it hasnt been 120 seconds turn off the port
if (ReefAngel.DCPump.Mode==Custom)
ReefAngel.PWM.SetActinic( ElseMode(40,20,true )); // ElseMode on sync mode, 40 +/- 20%
if( ReefAngel.DisplayedMenu==FEEDING_MODE ) ReefAngel.PWM.SetActinic(20);
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE ) ReefAngel.PWM.SetActinic(0);
if (hour()<12 || hour()>=22) ReefAngel.PWM.SetActinic(30);
ReefAngel.Portal( "Sacohen","Seth0310" );
int x,y;
// Water Level
strcat(text," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,39,75,"Salinity:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,99,75,text);
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
if (WaveSync)
return NewSpeed;
return AntiSpeed;
