Help needed for my DC pump automation project
Re: Help needed for my DC pump automation project
No just the V shoukd be lowercase...other than that i dont know. Try reversing the wires to the pwm port.
Thanks for the advise i switch the wire on the dimming module and it WORK!
Now when i tried fixing the New Generation Waveline DC6000 on Channel 1 i realise that the connector on the pump is male! unlike the other DC pumps which is Female. so What i did was change the RA Jebao Cable to Female so i can connect to the waveline DC6000, however it didnt work on me. cant seems to control it like what i have done with the Waveline DC10000.
this is the code i use any thing wrong?
ReefAngel.DosingPumpRepeat( Port2,0,60,35 );
ReefAngel.StandardLights( Box1_Port1,14,0,23,0 );
ReefAngel.RF.SetMode( Constant,50,10 );
ReefAngel.PWM.SetChannel(0,100); // Sets channel 0 to 100%, DC10000
ReefAngel.PWM.SetChannel(1,100); // Sets channel 1 to 100% DC6000
Also i want to change the WP40s from daylight and actinic port to the Dimming module channel 2 and 3 how do i change the code?
ReefAngel.PWM.SetDaylight( NutrientTransportMode(77,90,3000,true) ); // Nutrient Transport on sync mode
ReefAngel.PWM.SetActinic( NutrientTransportMode(77,90,3000,false) ); // Nutrient Transport on anti-sync mode
Thank you so much!
Thank you so much!
Oh... That's good to know the waveline has a different connector.
Yes, just change your code from actinic/daylight to channel just like you did for the other pumps
But Roberto, i cant seems to control the DC6000 as i did with the DC10000, any idea what went wrong?rimai wrote:Oh... That's good to know the waveline has a different connector.
As for the Code i was thinking :
ReefAngel.PWM.SetChannel( NutrientTransportMode(77,90,3000,true) );
but how to assign channel 2?
ReefAngel.PWM.SetChannel( 2, NutrientTransportMode(77,90,3000,true) );
rimai wrote:ReefAngel.PWM.SetChannel( 2, NutrientTransportMode(77,90,3000,true) );
Ok confirm it works on my WP 40s, i have successfully hook up my DC10000(return Pump) my WP40s(wave makers) to the dimming module, however the Waveline DC6000 didnt work. anyone knows what could be the reason?
I'll let you know in a few days.
I'm getting a package of goodies from China tomorrow
There should be WP-25, DC-3000, DC-5000, DC-10000, DC-6000 and DC-9000 in this package
Holy batman waterpumpsrimai wrote:I'll let you know in a few days.
Great!!!
