I just started dosing Kalk in my ATO water and I wanted to know how to set the ATO to turn off if the pH reaches 8.4, then wait for a while (let's say an hour) and check it again. Basically I don't want an ATO timeout to occur, I just want it hold off refilling until the pH is at a safe value.
Steve
Control ATO on pH value
Re: Control ATO on pH value
I'm not a pro on coding but this is what I'm using for a similar thing, but with Salinity.
Basically is the Salinity is below 33.5 then the ATO will not turn on.
I would think that to do it for PH it would be
or whatever port your ATO is on.
Then when the PH drops below 8.4 and if the ATO float switch is still Active then the water will start flowing again until the float is at the correct level or the PH rises again.
if (ReefAngel.Params.Salinity<335) ReefAngel.Relay.Off(ATO_Pump);
if (ReefAngel.Params.PH>840) ReefAngel.Relay.Off(Port8);
The wizard will write code to control a port according to Ph levels.
This is the code to turn port 5 on at 8.18 and off at 8.40
Maybe you can make this work.
ReefAngel.PHControl( Port5,818,840 );
