feeding mode code
rossbryant1956
feeding mode code
Post by rossbryant1956 »
I am having trouble getting my feeding mode to work again since installing my new relays. Here is a snippet of my code:
   // Define Relay Ports by Name
    #define DT_LightsOne       1
    #define DT_LightsTwo       2
    #define Unused3            3
    #define Unused4            4
    #define DT_LWM             5
    #define GT_LWM             6
    #define Unused7            7
    #define Unused8            8
    #define Unused11           Box1_Port1
    #define Unused12           Box1_Port2
    #define GT_LightsOne       Box1_Port3
    #define GT_LightsTwo       Box1_Port4
    #define DT_RWM             Box1_Port5
    #define GT_RWM             Box1_Port6
    #define DT_Heat            Box1_Port7
    #define DT_Pump            Box1_Port8
    #define RV_Heat            Box2_Port1
    #define RV_Pump            Box2_Port2
    #define GT_Heat            Box2_Port3
    #define Unused24           Box2_Port4
    #define GT_OverFill        Box2_Port5
    #define GT_Fill            Box2_Port6
    #define Skimmer            Box2_Port7
    #define GT_Pump            Box2_Port8
    void setup() {
        ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize the menu
        ReefAngel.FeedingModePortsE[0] = DT_Pump; // Turn off on Box1 when feeding mode is activated is activated
        ReefAngel.FeedingModePortsE[1] = Skimmer | GT_Pump; // Turn off on Box2 when feeding mode is activated is activated
        ReefAngel.WaterChangePorts = DT_LWM | GT_LWM ; // Turn off when water change mode is activated
        ReefAngel.WaterChangePortsE[0] = DT_RWM | GT_RWM | DT_Heat | DT_Pump; // Turn off on Box1 when water change mode is activated
        ReefAngel.WaterChangePortsE[1] = GT_Heat | GT_Pump | Skimmer | GT_Fill | RV_Heat; // Turn off on Box1 when water change mode is activated
The ports that need to be toggled are on relay boxes 1 & 2: box1_port8 and box2_port8. The ports it is switching are: Box2_port1, box2_port3, and box2_port5. I haven't tested the water change mode but it will probably act the same way. Here is the code snippet I call feeding mode with.
// if the hour is 2p or 8p, minute is 55 and seconds is 0, start the feeding mode
          if ( ((hour() == 14) || (hour() == 20)) &&
          (minute() == 55) &&
          (second() == 0) )
          ReefAngel.FeedingModeStart();
Re: feeding mode code
So you have three relay boxes or two?
The FeedingModePortsE[0] is the first expansion box. The main relay box is still FeedingModePorts
rossbryant1956
I have three, there are no devices on the first relay that need switching. should i do a line like FeedingModePort=0 and then my other lines? For some reason it is getting confused. Thx
Ahh i see the problem.
You dont use the relay port number for that (ie 1-8, 11-18, 21-28)
You need to use Port1Bit and Port2Bit and so forth.
The PortXBit is the same whether its Box1 or Box2 or main relay box.
rossbryant1956
thx so much. I'll fix it in the next day or so.
