Here is my code:
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port4Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port3,20,0,14,0 );
ReefAngel.DosingPumpRepeat( Port4,0,60,125 );
ReefAngel.DCPump.SetMode( ReefCrest,100,10 );
ReefAngel.Portal( "jedimasterben" );
int x,y;
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,49,66, "SAL:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.Salinity,COLOR_DARKKHAKI,73,66, 10 );
By having a single expansion and one attachment, have I really filled the memory capacity? Is that all it takes? My code is exactly what the RA Wizard spits out, installed from the latest 1.0.9 installer.
