Hi all i currently has a light set which has 3 channels,
Channel 1: white
Channel 2: Blue
Channel 3: red, green, uv
i am using the Analog Dimming expansion will be using 3 channels to control the light set.
Question 1) how to code it to run turn on gradually for the 3 channels during the day for example:
before 11 am: channel 2(blue on 5%) act as moonlight
from 11 am onwards slowing and gradually ram up channel 2 (blue to 30%) at the same time ram up channel 3 slowly and gradually to 50% and also Channel 1 concurrently ram up to 70%- Maybe the whole set rise process will take 30-45mins
then throughout the day all channel 1 and 2 gradually ram up to max 80% at 5pm.
after 5pm it gradually tone down to sunset at 11pm leaving channel 2 on at 5%(moonlight)
Question 2) how to create a lightning storm effect whereby the white (channel 1) blinks at 90% Blue (channel2) blinks at 50% and red (channel 3)at 70%
I am just using my imagination to mimic the colors of the nature not sure if it will turn out nice
Question on LED dimming
Re: Question on LED dimming
rimai wrote:Did you try the wizard?
Sent from my SPH-L710 using Tapatalk 4
Just walk thru the wizard. Guess that will solve most of my codes.
How do I add lightning modes? Question 2.
Thanks Roberto.
Check this one:
http://forum.reefangel.com/viewtopic.ph ... &start=120
rimai wrote:Check this one:
After reading thru i still have no idea how to include a lightning or storm mode in my code( too complex for me )
Sorry for being a pain in the xxx.
below are my codes appreciate if anyone can assist me in this
byte WCstatus=0;
ReefAngel.AddWifi();//Setup Wifi
InternalMemory.OverheatTemp_write( 300 );
ReefAngel.Relay.On( Port1 ); //skimmer
ReefAngel.Relay.On( Port3 ); //MP40
ReefAngel.Relay.On( Port4 ); //Cabinet Light
ReefAngel.Relay.On( Port5 ); //WP40 Right
ReefAngel.Relay.On( Port6 ); //BM Doser
ReefAngel.Relay.On( Port7 ); // DC10000
ReefAngel.Relay.On( Port8 ); // Always On
ReefAngel.Relay.On( Box1_Port2 ); //WP40 Left
ReefAngel.Relay.On( Box1_Port5 ); //LED
ReefAngel.Relay.On( Box1_Port6 ); //Salt Mix Pump
ReefAngel.Relay.On( Box1_Port7 ); //Always On PWM
ReefAngel.Relay.On( Box1_Port8 ); //LED
ReefAngel.DosingPumpRepeat( Port2,0,60,35 );
ReefAngel.StandardLights( Box1_Port1,14,0,23,0 );
ReefAngel.RF.UseMemory = true;
ReefAngel.RF.SetMode( NutrientTransport,30,10 );
ReefAngel.PWM.SetChannel(0,100); // Sets channel 0 to 100%
ReefAngel.PWM.SetChannel( 1, NutrientTransportMode(77,90,3000,true) ); // Nutrient Transport on sync mode
ReefAngel.PWM.SetChannel( 2, NutrientTransportMode(77,90,3000,false) ); // Nutrient Transport on anti-sync mode
ReefAngel.PWM.SetChannel( 3, PWMParabola(15,0,23,0,0,30,0) ); // (White)Set channel 3 to start 3pm at 10% to top 30% then end at 8pm at 10%
ReefAngel.PWM.SetChannel( 4, PWMParabola(10,0,23,59,0,40,0) ); // (Blue)
ReefAngel.PWM.SetChannel( 5, PWMParabola(15,0,23,0,0,20,0) ); // (Red)
//ReefAngel.PWM.SetDaylight( TidalSwellMode(80,true) ); // Tidal Swell at 40% on sync mode
//ReefAngel.PWM.SetActinic( TidalSwellMode(80,false) ); // Tidal Swell at 40% on anti-sync mode
//ReefAngel.PWM.SetDaylight( LongPulseMode(50,80,20,true)); // long pulse minimum power at 50% max at 80 lasting for 20 sec Sync
//ReefAngel.PWM.SetActinic( LongPulseMode(50,80,20,false)); // long pulse minimum power at 50% max at 80 lasting for 20 sec AntiSync
//ReefAngel.PWM.SetDaylight( ReefCrestMode(80,40,true) ); // ReefCrest at 80%max +-40% on sync mode
//ReefAngel.PWM.SetActinic( ReefCrestMode(80,40,false) ); // ReefCrest at 80%max +-40% on anti sync
if (ReefAngel.WaterLevel.GetLevel()>=80) //Turn off skimmer if waterlevel exceed 80%
ReefAngel.Relay.Off(Port1);
ReefAngel.Relay.On(Port1);
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(Constant,0,0);
ReefAngel.PWM.SetChannel(1,30);
ReefAngel.PWM.SetChannel(2,30);
ReefAngel.PWM.SetChannel(0,75);
ReefAngel.Portal( "Amos%20Poh" );
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 10, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 10, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,46, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,46, ReefAngel.Params.Salinity );
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,63, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,63, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawOutletBox( 12, 79, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 98, TempRelay );
Curt is working on something:
http://forum.reefangel.com/viewtopic.php?p=31968#p31968
Make sure you follow that thread.
