So I finally added a relay expansion and can now plug in my two doing pumps. So how should I set this up, hard code it or adjust though the portal.
Has the final lnevo/kirkwood code been posted somewhere, I would love to be able to track the dosing.
If I add the code can I then adjust through the portal, will that over ride the code ??
Still using digital timers for my dosing until I can figure this out, unless I'm over thinking this.
Chris
Dosing Pump Question
Re: Dosing Pump Question
The code is in my pde/ino. See my signature. Theres nothing in the library yet and not on my radar at this time. It should be easy to pull out of my file. Keep in my my extensive use of InternalMemory locations and the calibrate/tracking are optional.. So really only one function. Try porting it over to yours and I'll help you online with any issues. This thread can serve to help people do the same.
Thanks Lee, Ill check it out
