How hard is this gonna be?
Re: How hard is this gonna be?
I dont even know how to start generating any codes. I have read and read so much i cant see straight lol.
I have RAGen open and I have Arduino open and have looked at the drop down menus in each and cant sem to figure out where to start. guess I will go back to the tutorials again and read some more.
I need a teacher lol
Tank 1-34G RSM reef tank. Rapidled DIY premium 24 kit, Reef Angel, (2) Hydor Evolution 550's, Hydor slim skim, JBJ chiller. Tank 2- Ocanic BC14, nanocustoms ballasts, hydor nano, saphire skimmer.
Open RAGen
Select PDE tab
Click in each port and choose what you want on the right side
That's it
Once you go through all 8 ports, click generate
Select PDE tab
That's it
oh ok yeah I seen how to do that but that doesnt give me the options to ramp anything up or down or create a starting intensity of the LEDS or change the timing curve of the pumps for wavemaking function.
that part you just mentioned seems simple enough but it doesnt appear to give me the options to change things around and rename the ports?
// Autogenerated file by RAGen (v1.1.0.126), (10/22/2011 15:14)
// RA_102211_1514.pde
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
ReefAngel.LightsOnPorts = B01010110;
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.StandardATO(Port1);
ReefAngel.MHLights(Port3);
ReefAngel.Wavemaker1(Port4);
ReefAngel.Wavemaker2(Port5);
ReefAngel.StandardFan(Port7);
#define VersionMenu
#define wifi
#define SIMPLE_MENU
ok so that should make it so port 7 is my fan which should go on with my lights? and it should make it so wavemaker 2 only goes on when my lights are on as well?
Now what do I do? lol
Good. that's a start.
Remeber, we have to go doing baby steps.
If you tackle everything at once, everything goes wrong and you won't be able to find out what it is.
Let's read what you generated to make sure that's what you have plugged in the relay box.
Port1 - ATO pump
Port2 - Lights
Port3 - Lights
Port4 - WM Pump 1
Port5 - WM Pump 2
Port 6 - always on, no matter. Will not turn off for anything
Port 7 - Fan
Port 8 - always on, no matter. Will not turn off for anything
Is this correct?
Here is the first thing I'd recommend: Put your fan on port 4 and move wm pumps to port 5 and 6. These ports have special dampening components to help minimize the spikes generated by pumps.
On RAGen, there is a section for Ports toggled during modes.
Make sure to select which port you would like turned off for feeding and water change.
Port1 - ATO pump
Port2 - Lights
Port3 - Lights
Port4 - WM Pump 1
Port5 - WM Pump 2
Port 7 - Fan
Is this correct?
I need to run the fan on 7 or 8 because the plug wont fit any other place...its a block style plug for 12V.
yes I made it so port 6 and 8 are always on. The WM ports I just left them where they came set up...i didnt change those at all.
port one is ATO
port 2 is my moonlight
port 3 is nothing
port 4 is nothing at the moment
port 5 is WM
port 6 is WM
port 7 is nothing at the moment
port 8 is my fans currently
this is are port #s according to the power supply box not the display. the display as we discussed befoe are reading one number less then actual. which also throws me off all the time.
port one is ATO
port 3 is nothing
port 5 is WM
port 6 is WM
Will you want to stop the WM pumps on feeding and/or water change mode?
Yes I want to shut off the WM for feeding but not water changes
So, your code should be something like this then:
Port1 - ATO
Port5 - WM
Port6 - WM
Port8 - Fan that follows the same schedule as lights
ReefAngel.FeedingModePorts = B00110000;
ReefAngel.Wavemaker1(Port5);
ReefAngel.Wavemaker2(Port6);
ReefAngel.StandardLights(Port8);
Port5 - WM
Port6 - WM
I so what do the other ports not mentioned do? I need a port for moon lights too
You said port 3,4 and 7 have nothing.
So, we are not touching them for now.
The moonlight, I'm just going to have it go on when Port 8 is off and vice-versa.
Is it how you want or you prefer having specific time on/off for them?
Yeah the moonlights On when day lights off
k i am trying to load that code you gave me and I keep getting an error saying problem uploading to board??
I wish I could. I tried to copy/paste and it wont let me. its in the black box with orange writing. I see a line that says not in sync, another that says protocal error. but its a lot of stuff. it goes on like its loading to the boad, the controller resets and then i get the error.
I watched the youtube video about uploading the internal memory times. this is something i didnt do...am I suppose to do this or is this something in the codes you gave me to copy/paste? or something i dont need to do?
Can you check on menu Tools->Board and make sure that you have "Reef Angel Controller w/ optiboot" selected?
that is correct. that is what it shows selected.
Here is the code:
And the Feature file
#define MinimumPWM 17
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
ReefAngel.WaterChangePorts = B00000000;
ReefAngel.OverheatShutoffPorts = B00000000;
ReefAngel.LightsOnPorts = B10000000;
ReefAngel.Relay.On(Port5);
ReefAngel.Timer[1].SetInterval(InternalMemory.WM1Timer_read());
ReefAngel.Timer[1].Start();
// PWM and Moonlight
if (bitRead(ReefAngel.Relay.RelayData,Port8-1))
ActinicPWMValue=PWMSlope(InternalMemory.StdLightsOnHour_read(),InternalMemory.StdLightsOnMinute_read(),InternalMemory.StdLightsOffHour_read(),InternalMemory.StdLightsOffMinute_read(),MinimumPWM,InternalMemory.LEDPWMActinic_read(),60,0);
DaylightPWMValue=PWMSlope(InternalMemory.StdLightsOnHour_read(),InternalMemory.StdLightsOnMinute_read(),InternalMemory.StdLightsOffHour_read(),InternalMemory.StdLightsOffMinute_read(),MinimumPWM,InternalMemory.LEDPWMDaylight_read(),60,0);
ReefAngel.Relay.Off(Port2);
ActinicPWMValue=0;
DaylightPWMValue=0;
ReefAngel.Relay.On(Port2);
// Cloud and lightining
CheckCloud();
// Wavemaker Code
ReefAngel.Relay.Toggle(Port6);
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if (lightningchance)
int x=0;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
// AutoGenerated file by RAGen (v1.1.0.124), (10/22/2011 19:43)
* Copyright 2010-11 Curt Binder
* Licensed under the Apache License, Version 2.0 (the "License")
#define VersionMenu
#define ATOSetup
#define StandardLightSetup
#define WavemakerSetup
#define WDT
Roberto....YOU ARE THE MAN!!!!! Talk about a real stand up guy! He just spent a good amount of time helping me out and has got me up and running.
If anyone is reading this who is thinking about buying a Reef Angel and is having doubts, Just go buy this thing!!! The man behind the product is top notch! His customer service skills cant be beat!!!!
I'm using Inventronics EUC -025S070DS drivers and I noticed my actinic channel started to "strobe" this week while ramping up/down. Since my other driver driving the white LEDs didn't do this I thought maybe the driver was bad. I have a replacement coming, hopefully it works like the other, if not, I guess I'll pin down the point where it stops flickering and use that as my starting point too. Great info, as always, Roberto!rimai wrote:The flickering is a limitation of the Meanwell drivers and not RA.
http://www.meanwell.com/search/eln-60/eln-60-spec.pdf
If you look at the datasheet, this happens right about 15%, where the signal fluctuates from 0% to 15% and any very slight change on the signal will cause it to go either 0% or 15%, which causes the effect you perceive as flickering.
Not all drivers present this behavior though. I've handled drivers that didn't do it and some that did. I don't know if they were from different batches or what made them not present this behavior.
What I recommend is using a minimum for the slope of 15% or higher. Since you dialed it down to 800mA, it will be slightly higher, probably close to 20% in your case.
But you can't change the start percentage of the slope on the preloaded code.
You will need to play around to see what is the minimum it will take without flickering.
Our of curiosity, does the actinic channel also present the same behavior?
