How hard is this gonna be?
Fourseventeen
Re: How hard is this gonna be?
Post by Fourseventeen »
I so what do the other ports not mentioned do? I need a port for moon lights too
Tank 1-34G RSM reef tank. Rapidled DIY premium 24 kit, Reef Angel, (2) Hydor Evolution 550's, Hydor slim skim, JBJ chiller. Tank 2- Ocanic BC14, nanocustoms ballasts, hydor nano, saphire skimmer.
You said port 3,4 and 7 have nothing.
So, we are not touching them for now.
The moonlight, I'm just going to have it go on when Port 8 is off and vice-versa.
Is it how you want or you prefer having specific time on/off for them?
Fourseventeen
Yeah the moonlights On when day lights off
Fourseventeen
k i am trying to load that code you gave me and I keep getting an error saying problem uploading to board??
Can you post the error you are getting?
Fourseventeen
I wish I could. I tried to copy/paste and it wont let me. its in the black box with orange writing. I see a line that says not in sync, another that says protocal error. but its a lot of stuff. it goes on like its loading to the boad, the controller resets and then i get the error.
I watched the youtube video about uploading the internal memory times. this is something i didnt do...am I suppose to do this or is this something in the codes you gave me to copy/paste? or something i dont need to do?
Can you check on menu Tools->Board and make sure that you have "Reef Angel Controller w/ optiboot" selected?
Fourseventeen
that is correct. that is what it shows selected.
Here is the code:
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#define MinimumPWM  17
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
  ReefAngel.FeedingModePorts = B00110000;
  ReefAngel.WaterChangePorts = B00000000;
  ReefAngel.OverheatShutoffPorts = B00000000;
  ReefAngel.LightsOnPorts = B10000000;
  ReefAngel.Relay.On(Port5);
  ReefAngel.Timer[1].SetInterval(InternalMemory.WM1Timer_read());
  ReefAngel.Timer[1].Start();
  // Specific functions
  ReefAngel.StandardATO(Port1);
  ReefAngel.StandardLights(Port8);
// PWM and Moonlight
  if (bitRead(ReefAngel.Relay.RelayData,Port8-1))
    ActinicPWMValue=PWMSlope(InternalMemory.StdLightsOnHour_read(),InternalMemory.StdLightsOnMinute_read(),InternalMemory.StdLightsOffHour_read(),InternalMemory.StdLightsOffMinute_read(),MinimumPWM,InternalMemory.LEDPWMActinic_read(),60,0);
    DaylightPWMValue=PWMSlope(InternalMemory.StdLightsOnHour_read(),InternalMemory.StdLightsOnMinute_read(),InternalMemory.StdLightsOffHour_read(),InternalMemory.StdLightsOffMinute_read(),MinimumPWM,InternalMemory.LEDPWMDaylight_read(),60,0);
    ReefAngel.Relay.Off(Port2);
    ActinicPWMValue=0;
    DaylightPWMValue=0;
    ReefAngel.Relay.On(Port2);
// Cloud and lightining
  CheckCloud();
  // Wavemaker Code
    ReefAngel.Relay.Toggle(Port6);
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
    if (lightningchance)
      int x=0;
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
And the Feature file
// AutoGenerated file by RAGen (v1.1.0.124), (10/22/2011 19:43)
 * Copyright 2010-11 Curt Binder
 * Licensed under the Apache License, Version 2.0 (the "License")
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define DisplayLEDPWM
#define StandardLightSetup
#define WavemakerSetup
#define WDT
#endif  // __REEFANGEL_FEATURES_H__
Fourseventeen
Roberto....YOU ARE THE MAN!!!!! Talk about a real stand up guy! He just spent a good amount of time helping me out and has got me up and running.
If anyone is reading this who is thinking about buying a Reef Angel and is having doubts, Just go buy this thing!!! The man behind the product is top notch! His customer service skills cant be beat!!!!
StuGotz
Post by StuGotz »
rimai wrote:The flickering is a limitation of the Meanwell drivers and not RA.
http://www.meanwell.com/search/eln-60/eln-60-spec.pdf
If you look at the datasheet, this happens right about 15%, where the signal fluctuates from 0% to 15% and any very slight change on the signal will cause it to go either 0% or 15%, which causes the effect you perceive as flickering.
Not all drivers present this behavior though. I've handled drivers that didn't do it and some that did. I don't know if they were from different batches or what made them not present this behavior.
What I recommend is using a minimum for the slope of 15% or higher. Since you dialed it down to 800mA, it will be slightly higher, probably close to 20% in your case.
But you can't change the start percentage of the slope on the preloaded code.
You will need to play around to see what is the minimum it will take without flickering.
Our of curiosity, does the actinic channel also present the same behavior?
I'm using Inventronics EUC -025S070DS drivers and I noticed my actinic channel started to "strobe" this week while ramping up/down. Since my other driver driving the white LEDs didn't do this I thought maybe the driver was bad. I have a replacement coming, hopefully it works like the other, if not, I guess I'll pin down the point where it stops flickering and use that as my starting point too. Great info, as always, Roberto!
